Home > General > This weekend I'll be mostly.....
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Wearing overalls, changing drive belt and air con condensor.
(Lots of tea and swearing.....)
Post #54197 12th Mar 2011 9:29am
johnatandy
England 2005 Range Rover Vogue 4.4 V8 Oslo Blue
I did the drive belt replacement, a word of advise, have a diagram of the belt route or draw one before you start, its like the krypton factor to put back on if you dont.
Good luck with that Thumbs Up
John
Post #54203 12th Mar 2011 9:48am
Richcl
Any tips, shortcuts? Very Happy
Post #54205 12th Mar 2011 9:52am
johnatandy
The hardest thing to get off for me was the Viscous fan(Left hand thread) you do need some type of locking tool to stop the pully's turning when trying to undo the fan.
I think i just made one, can't be sure as it was a couple of years back.
The only other suggestion is maybe change the air con belt at the same time, something i didn't do and it is now squealing a bit Big Cry
I think it has been covered on here before, or was that the other forum Embarassed .
John
Post #54207 12th Mar 2011 9:59am
Richcl
I have brought the viscous tools, probably could have bodged the tools but will speed up the job.
Yes, will replace air con belt to.
Cheers Smile
Post #54210 12th Mar 2011 10:07am
Deffinatly have a pic of the belt route! Also the pully is plastic so dont put any load on it or it will break! I've done this! No real shortcuts a simple and easy job if you can get the fan off easy!
Post #54227 12th Mar 2011 12:16pm
Richcl
Thanks for tips, I'm going in.....
(Just been told at dealers to check altenator bearings, as they could be on the way out..... Neutral )
Post #54237 12th Mar 2011 1:16pm
Richcl
Managed to change drive belt without removing the viscous fan, a bit tight buit manageable.
Post #54284 12th Mar 2011 5:26pm
you've had a nice day to do that rich.. Thumbs Up ... - .- -.
Post #54294 12th Mar 2011 6:44pm
Richcl
I certainly did Scarey, My Son came round and helped (Apprentice mechanic, always useful!)
Changed both drive belts and air-con condensor, surprised how much of the car we had to strip down to fit it all!
Post #54304 12th Mar 2011 7:19pm
part of the requirement of owning a FFRR is to have a relative who's a mechanic..my sons a qualified mechanic so we have done well rich.. Thumbs Up ... - .- -.
Post #54305 12th Mar 2011 7:30pm
