Home > LPG > Lpg
Peopete
Lpg
What would be the maximum mileage you would advise lpg converting a 4.4 or 4.2sc ffrr, any advice and thoughts welcome chaps.
Post #510565 1st Apr 2019 8:07pm
Dolphinboy
Not sure why it makes any difference. if the engine is good and well looked after, LPg shouldn't matter? My LPG 4.4 V8 is on 190,000 miles now and was converted at 129,000. All worked 100% since! Thumbs Up
Once fitted make sure it is serviced every year (or 200 hours) and you should have no probs. Mine is a STAG system (Polish origin I believe) although the 4.2 SC copes better with a BRC system(not sure on the make name) and needs a lube system as well), as does the JAG 4.4 naturally aspirated.
Post #510576 1st Apr 2019 8:55pm
Peopete
Thanks for that dolphinboy, that makes my choice of rr easier knowing a well looked after one with higher mileage will be ok to convert to lpg and not having to spend 10k+ on a lower mileage rr Thumbs Up
Post #510579 1st Apr 2019 9:24pm
Peopete
We also have a few good installers in Birmingham ref reviews I've read who do both Brc and stag systems Thumbs Up
Post #510581 1st Apr 2019 9:27pm
Peopete
Can anyone recommend a good lpg installer in Birmingham, cheers
Post #510665 2nd Apr 2019 1:56pm
dingg1
not brum
but well worth the journey to get it done here instead
http://www.lpgc.co.uk/
Post #510671 2nd Apr 2019 2:55pm
Peopete
Cheers dingg1 Thumbs Up
Post #510704 2nd Apr 2019 5:50pm
