Home > In Car Electronics (L322) > MK4 unit won't go to sleep.
tveitan
Norway 2002 Range Rover HSE Td6 Oslo Blue
Hi,
i've got a MK4 DVD unit that's draining my battery. It won't shut down. I can see the red light illuminated after the car goes to sleep. No drain using the original MK3 unit. Not a big issue but i do prefer the MK4 graphics so does anybody have any suggestions on how to fix it? Very Happy
Thanks 2002 Range Rover Td6
Post #510547 1st Apr 2019 5:58pm
Pull it, dismantle it, have a look at the circuit board for corrosion, if so, clean with contact cleaner and toothbrush (preferably SWMBO's!) .
Post #510548 1st Apr 2019 6:19pm
tveitan
I have dismantled it, and it looks good. Clean and dry. Could it be a software issue? 2002 Range Rover Td6
Post #510549 1st Apr 2019 6:29pm
All was working OK with the Mk3 unit ?
Mk3 > Mk4 should be plug and play ? .
Post #510569 1st Apr 2019 8:25pm
tveitan
Yes, works perfect. It's all plug and play. The mk4 was also working fine, but my battery became weaker so I noticed that the mk4 didn't go to sleep. Put the mk3 back in and that solved the drain problem. 2002 Range Rover Td6
Post #510594 2nd Apr 2019 5:28am
If you can it might be worth trying a Firmware update. Do you happen to know what version the Firmware is?
Post #510613 2nd Apr 2019 8:55am
tveitan
Got the latest one, V32 with RR splash screen. Think i'll try to re-install the firmware. Hopefully that helps.
Is it possible to upgrade the firmware on the MK3 to get split-screen? 2002 Range Rover Td6
Post #510632 2nd Apr 2019 11:08am
Can't help with the mk3 satnav, I have the mk 4 as well. Thumbs Up
Post #510659 2nd Apr 2019 1:24pm
tveitan
No worries Smile I'll let u know if re-installing the firmware solves it. 2002 Range Rover Td6
Post #510705 2nd Apr 2019 6:09pm
tveitan
Installed stock firmware on it now, but it didn't help. Tok it apart afterwards and cleaned it with contact cleaner and toothbrush hoping it could help, but that didn't solve it either.
Anybody know if it works well to do some re-wiring to cut the power to it when igition is swiched off, and the easiest way to do it? 2002 Range Rover Td6
Post #511426 9th Apr 2019 9:51am
