Home > In Car Electronics (L322) > MK4 unit won't go to sleep. |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6410 |
Pull it, dismantle it, have a look at the circuit board for corrosion, if so, clean with contact cleaner and toothbrush (preferably SWMBO's!) .
1st Apr 2019 6:19pm |
tveitan Member Since: 10 Dec 2016 Location: Norway Posts: 47 |
I have dismantled it, and it looks good. Clean and dry. Could it be a software issue? 2002 Range Rover Td6 |
1st Apr 2019 6:29pm |
All was working OK with the Mk3 unit ?
1st Apr 2019 8:25pm |
Yes, works perfect. It's all plug and play. The mk4 was also working fine, but my battery became weaker so I noticed that the mk4 didn't go to sleep. Put the mk3 back in and that solved the drain problem. 2002 Range Rover Td6 |
2nd Apr 2019 5:28am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
If you can it might be worth trying a Firmware update. Do you happen to know what version the Firmware is? |
2nd Apr 2019 8:55am |
Got the latest one, V32 with RR splash screen. Think i'll try to re-install the firmware. Hopefully that helps.
2nd Apr 2019 11:08am |
Can't help with the mk3 satnav, I have the mk 4 as well. |
2nd Apr 2019 1:24pm |
No worries I'll let u know if re-installing the firmware solves it. 2002 Range Rover Td6 |
2nd Apr 2019 6:09pm |
Installed stock firmware on it now, but it didn't help. Tok it apart afterwards and cleaned it with contact cleaner and toothbrush hoping it could help, but that didn't solve it either.
9th Apr 2019 9:51am |
