Home > Technical (L322) > Ignition switch relay?
Tight777
United Kingdom 2007 Range Rover Vogue TDV8 Zermatt Silver
Occasionally when I turn the key I have no electrics, local mechanic said it's the ignition switch relay just change it.
Anybody help with where it is please?
2007 TDV8
Post #510479 1st Apr 2019 8:06am
Tight777
Can anybody point me to a diagram for the relays please?
Post #510952 5th Apr 2019 7:28am
anything in the WM.?
Post #510960 5th Apr 2019 8:18am
Tight777
I've been looking cant find one, only need a simple diagram.
Post #510977 5th Apr 2019 9:44am
Gsxr1250dave
Re: Ignition switch relay?
2007 TDV8
If it was so easy why didn't he do it then ??!??? Iv just replaced my ignition switch for intermittent no start.........same fault still present so its the starter solenoid which is next on my list. Mine is the m62 engine I'm not up on the tdv8 but if there was a relay and it was a known issue a Google search would find it I'm sure
Post #511044 5th Apr 2019 4:58pm
Nick591
The WM doesnt seem to have electrical schematics. A helpful member here supplied me with a number of schematics a while back from another source. I think JLR do a separate electrical manual. I know they used to do a book for the earlier models pre 2006 but since then I think its all on topix or something similar. People allude to the fact that you can subscribe to topix for a short time and download what you need? Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8
Post #511053 5th Apr 2019 6:08pm
Tight777
Well the problem went away on it's own but has now returned same as before.
I have a shiny new YWB101050 ignition relay but can't find where it goes (yes I've Googled)
It's not in the rear fuse box or the one under the bonnet with 10 or so screws.
There is a fuse box behind the passenger glove box, that has some relays behind it but I'm
not sure what they are or how to access them.
Any ideas?
Relay location diagram would be great.
Post #547730 20th Mar 2020 2:57pm
DucatiBrandon
United States 2007 Range Rover Supercharged 4.2 SC V8 Ipanema Sand
I’m having all sorts of strange things with mine as well. Typical RR garbage but nevertheless if your looking for the starter relay I believe it’s under the hood with a lot of screws around it. Probably labeled SM. I know my P38 that’s the one and when I meter my o7 it looks to be the same. Sorry but that’s a guess.
Post #547976 23rd Mar 2020 2:17am
Tight777
Post #548312 26th Mar 2020 8:40am
RRPhil
If it’s the interlock relay that you mean, it’s underneath the transfer box ECU, behind the battery (least it was for '02-'05 models)
Phil
Post #548330 26th Mar 2020 12:39pm
Tight777
Thanks Phil, got chance to look again yesterday, still can't find it, it's not behind the battery on a 07.
On a Plus note, I was wondering if a bad earth could be the cause and on removing the battery the earth
Lead wasn’t as tight as in have liked, fingers crossed.
Post #548510 28th Mar 2020 7:12am
RRPhil
This could be another wild goose chase, but Microcat does appear to show relays on top of the main fuse box. I’m not sure if the (BMW) fuse box in the glovebox changed after 2005, though? Does the Microcat illustration even mean that the relay is in the top of the fuse box, or is it just a convenient section to list its part number?
Phil
Post #548587 28th Mar 2020 5:50pm
Tight777
Thanks Phil that's just what I was looking for, but it's a bit of a wild goose chase.
I stripped it out and its not there.
Post #549423 5th Apr 2020 7:26am
Marzipan
United Kingdom 2009 Range Rover Vogue TDV8 Santorini Black
Have you seen the YouTube video by Hernandez? that may be of some help. Although you have already checked behind the battery, there are 2 large relays there on mine.
Post #549675 7th Apr 2020 9:03pm
