![]() | Home > General > Help me out the wifes on my back!! |
That does look low. It looks like they haven't adjusted it correctly.
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
Have you adjusted the forwards / aft position, to see if that gets it back to how it was before?
Ludzy Member Since: 27 Oct 2010 Location: Leicester Posts: 191 ![]() ![]() ![]() |
Yeah tried that. Here's a pic from the side with the wheel set to the max on up/down and in/out.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7970 ![]() ![]() ![]() |
Looks right to me
Hmm strange then. Just sat at the garage now as there having a look. Apparently there is a adjustment.
Problem/confusion solved.
Duh - the wife is always right did she not tell you that....... |
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 ![]() ![]() ![]() |
So just got in the car since Saturday and the drivers seat and wheel adjuster has no power what so ever so cant change memory setting or tinker with the seat and wheel position. I'm assuming that this area has no power as the red memory light does not even come on. Any ideas????? Fuse maybe??? |
Any connections under the seat loose ====================================
no all connections are solid. Wheres the fuses for these, and do the drivers seat and steering column on the same fuse?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35486 ![]() ![]() |
fuse locations could be in the manual or on rave.. ... - .- -.
Yeah just looking at rave now. Seems to be in the passenger fuse box. I'll go and have a look...................................? |
The fuse for the drivers side switch pack had gone so just swapped it for the passenger for now so all good. The steering wheel relay fuse is fine also but still no movement from it???? I hope it aint another trip to the garage that change my column. Dont know what else it could be?
