Home > Technical (L322) > Fan won’t knock off? Now flat battery |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 367 |
Problem compounded locked out and battery gone flat. Going to try and power through 13 pin electrics in the morning hopefully auxiliary power is wired up.
29th Mar 2019 6:47pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Final Stage Resistor (FSR / Hedgehog) classic symptoms
29th Mar 2019 10:08pm |
Thanks for this the fans seemed to be working but this other noisy fan was ongoing even with ignition off . Would FSR failure allow fans still to operate ? I was thinking that it was something to do with the FBH. will investigate better tomorrow after hopefully opening the car ! 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
29th Mar 2019 10:24pm |
Got into the car using the wiki and eventually found it in the manual lol. Worry number one resolved. Now need to get old FSR out too get correct part no and to stop battery drain 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
29th Mar 2019 11:27pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
There are lots of great videos on youtube showing how to change the FSR sir
30th Mar 2019 12:46am |
Cheers, all dismantled - 4 screws in panel above pedals, only problem is that the OBDM connector is in the left side, managed to manouver full panel away from pedals and off to side of door.
30th Mar 2019 5:05pm |
Sarchopperman Member Since: 11 Aug 2017 Location: Aberdeenshire Posts: 33 |
Posting just to support Jo 90's diangnostic.
25th Mar 2021 6:48pm |
