Home > Technical (L322) > Fan won’t knock off? Now flat battery
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
Stopped for fuel and on setting off again the fan noise was a lot louder than usual. Tried adjusting settings, Air con off and on etc but still a back ground noise.
At hone now and noise is still there even with ignition off and car locked. Seems to “slowdown” after a while but speeds up if a door is opened.
Noise is behind dash but no air being blown through vents with ignition off. It is not the radiator fan or the ecu fan.
Can’t see what fuses to pull to try and see what it is .....any ideas?
thanks 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #510228 29th Mar 2019 2:14pm
V8 Bob
Problem compounded locked out and battery gone flat. Going to try and power through 13 pin electrics in the morning hopefully auxiliary power is wired up.
Once I get in if i disconnect battery , charge it then reconnect what issues am I likely to encounter - I don’t have a I’d tool 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Post #510257 29th Mar 2019 6:47pm
Final Stage Resistor (FSR / Hedgehog) classic symptoms
http://metricrat.co.uk/tag/fsr/
or
http://www.fullfatrr.com/forum/topic781.ht...eplacement (wiki) .
Post #510270 29th Mar 2019 10:08pm
V8 Bob
Thanks for this the fans seemed to be working but this other noisy fan was ongoing even with ignition off . Would FSR failure allow fans still to operate ? I was thinking that it was something to do with the FBH. will investigate better tomorrow after hopefully opening the car ! 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Post #510272 29th Mar 2019 10:24pm
V8 Bob
Got into the car using the wiki and eventually found it in the manual lol. Worry number one resolved. Now need to get old FSR out too get correct part no and to stop battery drain 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Post #510275 29th Mar 2019 11:27pm
There are lots of great videos on youtube showing how to change the FSR sir Thumbs Up
Quite simple but a little frustrating... Rolling Eyes
Post #510279 30th Mar 2019 12:46am
V8 Bob
Cheers, all dismantled - 4 screws in panel above pedals, only problem is that the OBDM connector is in the left side, managed to manouver full panel away from pedals and off to side of door.
Got old one out after watching you tube’s it is a BMW part ! Not what I expected in a 2012 so probably been changed before.
Battery on charge and new part coming Monday at a third of BMW price. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Post #510342 30th Mar 2019 5:05pm
Sarchopperman
United Kingdom 2011 Range Rover Vogue TDV8 Epsom Green
Posting just to support Jo 90's diangnostic.
Had a call from wife saying that vent fan motor continues to run after engine stopped on 2011 FFRR. I suggested to just leave it and see if it shut down on its own. Well it didn't and flattened the battery. Luckily facility to charge the battery and got the car home. I had replaced the FSR on our other FFRR a while ago and obviously had the foresight to buy two replacements.
They are fiddly but definitely a diy job. Replaced and fixed ........ very satisfying. If you're slick and can find the fsr quickly it is a 30 min job. Have ordered two more ......... £25 each off eBay. RR L322 TDV8 4.4 SE 2019 to present
RR L322 TDV8 4.4 - 2016 to present
Discovery 2 TD5 - 2010 to 2016
Discovery 1 - 2000 to 2010
Post #588939 25th Mar 2021 6:48pm
