Home > Technical (L322) > Deployable steps stripped bolt
dazza1983
United Kingdom 2011 Range Rover Vogue 4.4 V8 Santorini Black
Hey guys
Tonight I noticed that my drivers deployable side step sits almost touching the front jack point you could possibly slide a piece of paper between the two just. The rear has a little gap whilst the passenger has a small gap both front and rear?
So I tried to loosen the bolts at the front and pull it down slightly but it didn’t want to know.
Whilst I was under there I thought I would check all the bolts holding the steps on as I only fitted them 4 or so weeks ago.
Then as I was checking them I remembered that I over tightened one of the small m6 bolts that go into the side so as I went to check it’s tightness it was just spinning.
Now my questions are
Would it be the bolt or the thread in the car that was stripped? Seen as the bolt is a2 stainless and I’m guessing the bolt hole is steel so the stainless should be softer.
Will the bolt fall out? Kind of retoracle because it hasn’t fallen out in 4 weeks and my brain won’t work but seen as it is stripped I’m guessing that it won’t fall out because the threads won’t allow it to be unscrewed?
If this is the case then I guess it should be fine to leave it as it’s acting as a up and down support for the steps. Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #510041 27th Mar 2019 10:24pm
lazylabs
Are you sure you stripped the bolt thread?
The nuts are captive nuts so more likely that the weld holding the nut in place broke and therefore the nut it just spinning on the bolt..
This happened to me when I fitted my steps.. In the end I drilled a couple of access holes so I could get a Spanner on the nut and do it up..
Just a thought.. Current Family:
2012 FFRR 4.4 TDV8 Westminster
2013 Jaguar XFs 3.0d Sportbrake
2008 FFRR 3.6 TDV8 VSE (Gone)
2008 Ford Mondeo mk4 2.2tdci (Gone)
2006 S Class 320 CDI (Gone)
1998 P38a 4.6 VSE Oxford Blue 98k (Gone)
Vx Vectra C Estate 1.9cdti 150 (with a few twists) (Gone)
Other LR's in Family (2019 4.4 TDV8 AB)
Post #510049 27th Mar 2019 11:43pm
dazza1983
Interesting thought .::
No I’m not 100% it’s stripped. I didn’t want to remove the entire step again lol.
I think I may just leave it. You think all the other bolts will be fine in terms of strength and keeping the step bolted on etc? Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #510052 27th Mar 2019 11:58pm
lazylabs
I suspect they will be fine holding the steps on.
The steps sort of hook on anyway so very unlikely to fall off.. Current Family:
Post #510055 28th Mar 2019 12:24am
dazza1983
That was my chain of thought to lol Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #510056 28th Mar 2019 12:29am
