Deployable steps stripped bolt | |
Hey guys
Tonight I noticed that my drivers deployable side step sits almost touching the front jack point you could possibly slide a piece of paper between the two just. The rear has a little gap whilst the passenger has a small gap both front and rear?
So I tried to loosen the bolts at the front and pull it down slightly but it didn’t want to know.
Whilst I was under there I thought I would check all the bolts holding the steps on as I only fitted them 4 or so weeks ago.
Then as I was checking them I remembered that I over tightened one of the small m6 bolts that go into the side so as I went to check it’s tightness it was just spinning.
Now my questions are
Would it be the bolt or the thread in the car that was stripped? Seen as the bolt is a2 stainless and I’m guessing the bolt hole is steel so the stainless should be softer.
Will the bolt fall out? Kind of retoracle because it hasn’t fallen out in 4 weeks and my brain won’t work but seen as it is stripped I’m guessing that it won’t fall out because the threads won’t allow it to be unscrewed?
If this is the case then I guess it should be fine to leave it as it’s acting as a up and down support for the steps. Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
