Home > Technical (L322) > Heated and cooled seat help
Landyandy1765
United Kingdom 2010 Range Rover Vogue SE TDV8 Baltic Blue
Has anyone got a supplier or an alternative fix for the peliter unit in the heated seats
Post #509878 26th Mar 2019 10:21am
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Have you taken the unit out yet? you could try BB Reman they take all sorts of stuff apart and fix.
When I got my one out I found that the plastic ducting was cracked across which stopped it working, I got a new one from Dan, Duckworth`s there is a Ford Mustang part that some here have made fit?
Post #509890 26th Mar 2019 12:47pm
rjff
There's a lot of info on here if you search for this. Try peltier, heated seats, cooled seat etc.
Let us know if the control lights do anything and if all the seats are not working, or you can get cooling or heating out of any. More info always helps Thumbs Up
There are filters on each one, so check they are clear, just a pad of material which can be cleaned. If they are dirty I think they cause overheating of the peltier cell and it cuts out. Then as above for getting it out and checking the ducting. IIRC there are two units in each seat, and I assume you're talking about the front seats (base and back).
As I say, do a search. The units are expensive Shocked and some investigation may save your wallet grief, and you if the head of household finances finds out Mr. Green
Have a look at this for a start. Crack a tin, it's long.
https://www.fullfatrr.com/forum/topic44946...eated+seat Cheers
Richard
Gap IIDBT
Post #509893 26th Mar 2019 1:27pm
Landyandy1765
Hi I've had the seat apart and found the cracked duct . All the controls work and the seat I've got issues with starts up with the fan running then after 30 ISH seconds it cuts out .
Post #509898 26th Mar 2019 2:44pm
Tinman
That was the same as most people on here its the crack in the ducting that stops it working as said before plenty of info on the search? I`m afraid it`s hand in the pocket again. Big Cry
Post #509904 26th Mar 2019 3:56pm
rjff
Baben's post in this thread may help:
https://www.fullfatrr.com/forum/topic17447...duct+crack
but as Tinman says it might be time to pick your pocket. Cheers
Richard
Gap IIDBT
Post #509914 26th Mar 2019 5:33pm
Landyandy1765
I know you can pick up pelitors for next to nothing so I'm determined to buy the correct one to replace the broken one I have .
When I find the one to do the job I will put a pic and info list together and post on the site .
Post #509921 26th Mar 2019 6:16pm
GGDR
I've tried and failed:
https://www.fullfatrr.com/forum/post501998.html#501998
But all ears if you can find a way.
. Cheers, Greg
Post #509937 26th Mar 2019 7:56pm
Landyandy1765
I know a very clever guy who is itching to sort I out . Will keep you posted .
Post #509938 26th Mar 2019 8:12pm
Gsxr1250dave
Arrrrhhhh 1st world problems 😂
Post #509950 26th Mar 2019 9:02pm
GGDR
Any luck with your friend Landyandy?
. Cheers, Greg
Post #512808 22nd Apr 2019 11:32am
Landyandy1765
In the last two weeks I've received the peliter so will keep you updated . I will take loads of pics to show the start to finish progress.
Andy
Post #512819 22nd Apr 2019 1:41pm
GGDR
Nice one Andy.
You'l be popular if you crack it!
Keep us up to date.
Cheers,
Greg Cheers, Greg
Post #512843 22nd Apr 2019 6:20pm
steveball
United Kingdom 2010 Range Rover Vogue SE TDV8 Bournville
Watching this topic with baited breath and crossed fingers. Can’t quite stomach the cost of a new unit, but having switched the working unit from passenger to driver’s seat, I do hear quite a lot of moaning! Have kept the old unit in hope of a repair... Current: 2010 Range Rover L322
Vogue SE, TDV8 3.6, Bournville
Now gone: 2002 Range Rover L322
Vogue, TD6, Giverney Green
Post #512968 23rd Apr 2019 7:58pm
gg2201
The bf went to the effort of removing mine only to find all the ducting etc was in place. The IID tool also showed a fault Big Cry
However he persisted with diagnosis to find that not enough power was getting to the rear back seat fans only the best part of 2 Volts vs 12. He cleaned all the battery terminals and earth and ever since they have been perfect infact they are absolutely toasty now and get warm really quickly.
May be worth checking you are also getting the full juice to them as mine presented like dead fans with no obvious fault the ducts were still really flexible and not brittle. To be fair it is clear the drivers module has been replaced at some point in its life on mine though Laughing 2011 4.4 TDV8 Autobiography
Post #513168 25th Apr 2019 4:43pm
