Home > Technical (L322) > Heated and cooled seat help
Landyandy1765
United Kingdom 2010 Range Rover Vogue SE TDV8 Baltic Blue
Heated Cooled Seats
Found a replacement peliter on Flebay.
ordered from the states and for a lincoln . Du57-19N550-D . there are other units to use also
When delivered it was the same peliter unit but in different housing .
quite easy to Swap in to the range rover housing but take note the wiring colours are different but easy to work out the cross reference.
Been working fine since .
Cheers andy
Post #590955 12th Apr 2021 1:59am
Gordo51
Canada 2008 Range Rover Supercharged 4.2 SC V8 Barolo Black
Have this unit bookmarked on eBay but not sprung for it yet.
Peltier element for seat heating Range Rover L322 HHK500060 LR034450 repair
Post #590957 12th Apr 2021 2:19am
Ansi
Switzerland 2010 Range Rover Autobiography 5.0 SC V8 Adriatic Blue
Look for a complete Heater/cooler unit for Jaguar (XF I believe), these are exactly the same and makes the fix to a easy plug n' play thing.
I didn't knew that they are the same units so I did not look for a left-side unit, therefor I had to take it appart and swap the Peltier element otherwise it would have been a 20Min. job.
Post #590963 12th Apr 2021 6:18am
