Home > General > New to forum - looking at getting a L322 tdv8
telly-addict
Scotland 2011 Range Rover Vogue TDV8 Stornoway Grey
Found a couple of codes stored in the Transfer case control module that look rather suspicious;
P2789-00 Clutch adaptive learning at its limit
P186D-00 Clutch actuator is stuck
Looking like the Transfer case is the problem...
*edit* just realised I put this in the wrong thread.. Rolling Eyes
Post #509953 26th Mar 2019 9:13pm
That is the diff lock you get on them all.
The centre diff locks, then the other traction control is dealt with via electronicals and brakes. The optional diff lock is on the rear axle, which is an actual locking diff but it’s not common on the tdv8 but was standard on the SC. There is nothing that can't be fixed with a hammer😜😜
Post #509955 26th Mar 2019 9:18pm
Those faults do point to a problem in thetransfer case, there arent many spare parts for these mostly seals. There are normally a few knocking about on eBay. If you want a good read RRPhil did a teardown a while back on here. Shows how they together.
https://www.fullfatrr.com/forum/topic12404...5+teardown There is nothing that can't be fixed with a hammer😜😜
Post #509956 26th Mar 2019 9:21pm
telly-addict
Thanks, that is indeed a good read. Also leads me to think the problem is software.
Post #510018 27th Mar 2019 4:24pm
telly-addict
Drop links replaced. No more clunking Thumbs Up
Also changed the front brake pads, as I wasn't particularly impressed. Found what looked like cheap pads, replaced with Delphi and already better. Cool
Re-balanced the front wheels while they were off as they had hammer-on lead weights on the front face. Why people allow that on alloy wheels is beyond me. Censored
Finally, I fitted the EGR blanking plates referenced in Henda's thread here.
Car now driving lovely, aside from a bit of tyre scrubbing which I should get a look at tomorrow. Cool
Post #510707 2nd Apr 2019 6:20pm
Rom
Netherlands 2012 Range Rover Vogue TDV8 Santorini Black
Did you manage to get the transfercase fault sorted?
I have the same message within 5 min after startup and does not come back after clearing till the next drive. Not been able to find much information about it.
Edit
Never mind, just reading your other post in which you mentioned that changing the transfercase oil fixed it, Thx Smile
https://www.fullfatrr.com/forum/topic12404...;start=105 2012 4.4 TDV8 Vogue
2010 3.6 TDV8 Vogue
2003 3.0 Vogue - Gone
1998 4.6 HSE
Post #678460 21st Nov 2023 7:53pm
