![]() | Home > Technical (L322) > Snapped Bonnet Release |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1521 ![]() ![]() |
From memory as long as you can access enough of it with pliers to actuate the bonnet release, swapping wasn't a big deal.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3246 ![]() ![]() ![]() |
+1
I'm glad Weegie stepped in there with actually useful advice rather than my well meaning but vague "moral support"! |
edward19 Member Since: 11 Feb 2019 Location: South Coast Posts: 55 ![]() ![]() ![]() |
Thanks both of you. I've ordered what I think is the correct part number FPF500040, although it does state its for vehicles upto 2009 and mine is a 2011. However I cannot find an alternative anywhere and it looks the same!! |
Just so everyone knows there is a difference between 2002-09 L322 and 2010-12 L322 bonnet release cables. The former has a rubber boot with a metal clip (right pain that) surround, whereas the latter does not. A bit of grinding later and you can make the older part fit the later car. Feeding the cable through with a bit of string did not work but just pushing the new cable through the bulkhead from the drivers footwell was pretty straightforward. |
Thanks for the update! Good to know. |
