Home > Maintenance & Mods (L322) > Front brake judder
LR dont want problems themselves so hence higher specs on their pads and consider the weight of the FF stopping from speed...
a fiesta wont have that same stress on its brakes... ..
Post #509337 20th Mar 2019 4:25pm
nambFFRR
United Kingdom 2016 Range Rover Autobiography SDV8 Corris Grey
Pawl wrote:
They're Brembo boxed because Brembo bought them from another supplier to sell under their own brand. Exactly like Britpart , AllMakes etc do.
It might be worth checking condition of the upper control arm rubber bushes. If they're very tired / soft, they can effectively "amplify" any minor judder that's there from the discs or pads
I’ll check these items when I do the discs and pads. Thanks for the tip. My RR only has 50k miles and looks to have had an easy life, but I will check as suggested.
Post #509379 20th Mar 2019 9:56pm
bwelton
United Kingdom 2012 Range Rover Vogue SE TDV8 Zermatt Silver
I had the same problem. Worn disks, replaced with. Brembo at a garage, 6 months later I have slight judder and a bit of break squeel. Frustrating.
Next time I’ll get genuine LR Pads and Disks. -------------------------------------
MY 2012 4.4 TDV8
Post #516522 26th May 2019 6:03am
nambFFRR
Update
Finally fitted the front discs and pads....Brembo branded.
What can I say...simply awesome. The originals were shot
Time will tell whether these Brembo branded are any good but first impressions are promising
Caliper pins.....what a stupid design. Well copperslipped so hopefully they’ll be easy to remove next time. Hardest job was removing the caliper bolts. Took some effort but all sorted.
One minor problem. Backing plates. Mine are aluminium but the genuine replacements I bought are steel and didn’t fit! So big washers in the originals where the holes had been damaged by corrosion. Hopefully they will last until the next disc change.
Post #524169 8th Aug 2019 6:32pm
Full Fattie
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
I agree the pins are terrible. When I had a different at with Brembo calipers someone manufactured some reusable pins. Bigger at one end and essentially a split pin in the other. Worked great
Post #524188 8th Aug 2019 8:35pm
nambFFRR
I’ll have look out for some of these...
Post #524190 8th Aug 2019 8:48pm
Rapiscan
England 2007 Range Rover Vogue TDV8 Santorini Black
I replaced all my tdv8 Brembo calipered cars discs and pads with MTEC branded items a, few months ago, all four discs are cross drilled/grooved and the car stops smoothly and way shorter than before, interestingly even with 135000mls on the clock the Brembo caliper pins tapped out with ease, and all the caliper bolts unscrewed easily too. The heavily encrusted old discs were in a right old state upon inspection, especially the rears and the inner drum bit was appalling, I'm surprised the epb worked under the cir umstances! I'm guessing they were the original discs Shocked 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
I used to be indecisive and have a split personality... but we are ok now...I think?
Post #524205 9th Aug 2019 1:41am
