![]() | Home > Maintenance & Mods (L322) > Front brake judder |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35535 ![]() ![]() |
LR dont want problems themselves so hence higher specs on their pads and consider the weight of the FF stopping from speed...
bwelton Member Since: 26 May 2014 Location: Milton Keynes Posts: 140 ![]() ![]() ![]() |
I had the same problem. Worn disks, replaced with. Brembo at a garage, 6 months later I have slight judder and a bit of break squeel. Frustrating.
nambFFRR Member Since: 06 Aug 2018 Location: United Kingdom Posts: 191 ![]() ![]() ![]() |
Update
Full Fattie Member Since: 10 Aug 2018 Location: Sunderland Posts: 245 ![]() ![]() ![]() |
I agree the pins are terrible. When I had a different at with Brembo calipers someone manufactured some reusable pins. Bigger at one end and essentially a split pin in the other. Worked great |
I’ll have look out for some of these... |
Rapiscan Member Since: 28 Apr 2018 Location: North Lincolnshire Posts: 182 ![]() ![]() ![]() |
I replaced all my tdv8 Brembo calipered cars discs and pads with MTEC branded items a, few months ago, all four discs are cross drilled/grooved and the car stops smoothly and way shorter than before, interestingly even with 135000mls on the clock the Brembo caliper pins tapped out with ease, and all the caliper bolts unscrewed easily too. The heavily encrusted old discs were in a right old state upon inspection, especially the rears and the inner drum bit was appalling, I'm surprised the epb worked under the cir umstances! I'm guessing they were the original discs |
