Home > Maintenance & Mods (L405) > L405 Transfer Box Oil Change & Judder Bulletin Double Fl |
JoeDoyle Member Since: 08 Aug 2024 Location: Eastbourne Posts: 3 |
Did two transfer case oil changes, shudder lessened each time, will do a third change next week. Also did ZF filter and oil, front diff and electronic rear diff, hydraulic/power steering flush. Just purchased with 82k SDV8 the oil changes and adaption resets for each make a massive difference. |
17th Aug 2024 10:01pm |
PLOG Member Since: 19 Nov 2018 Location: Teesside Posts: 25 |
Has anyone managed to fix this long-term yet?
29th Aug 2024 2:27am |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 770 |
If a new transfer case hasn't solved it and the TCCM has definitely been updated, it is a possibility that you have a different problem to that of the transfer case judder in this thread. The transfer case judder I was experiencing was quite violent, not slight.
29th Aug 2024 5:07am |
I did a lot of reading about it beforehand and the LR Bulletin was exactly what I was experiencing (and still am), so I was convinced the double flush would work.
30th Aug 2024 2:14am |
knwatkins - Where did the judder / noise feel like it was coming from for you? It feels like it's coming from the rear left on mine. |
30th Aug 2024 2:18am |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1195 |
Same problem here, after two years of complaining about the clonk, they replaced the rear diff under warranty.
30th Aug 2024 7:17am |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 452 |
is there a bulletin out for this issue ?................its ok i found it |
4th Oct 2024 5:37pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35459 |
second post on page one. ... - .- -.
4th Oct 2024 6:10pm |
Did the flush, software update, didn’t work. Changed the transfer case and control module. Judder remained.
22nd Oct 2024 9:59pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2550 |
Did the ediff s/w update include recalibrating the ediff? |
23rd Oct 2024 2:37am |
Software update to control module, calibration through Gap tool self test. Changed the oil again yesterday, if anything it’s worse now, thinking of trying Dr Tranny
23rd Oct 2024 11:14am |
I was surprised to learn that a relatively local to me LR specialist workshop rebuilds ediffs. |
23rd Oct 2024 7:43pm |
been having this problem ,just done first flush -software updated calibration carried out .......will be driving it around for couple of days then do the second flush and fingers crossed judder sorted |
25th Oct 2024 9:43pm |
