Home > Technical (L322) > Help / guidance needed for IIDTool suspension calibration
jakebullet64
United Kingdom 2003 Range Rover Vogue 4.4 V8 Santorini Black
Hi there. I've an issue with the OSR being way lower than the other corners.
This has only occurred after a garage did some work to replace the same side driveshaft and abs sensor.
Anyway, I've taken the measurements and I've screenshot the numbers from IID. But how do I work out what the new settings should be?
Measurements from hub centre to wheel arch;
FL 520mm
FR 483mm
RL 461mm
RR 372mm
Any help Will be greatly appreciated.
Jake
 2003 Range Rover Vogue 4.4 on Gas
1961 88" 2.25 diesel - George
Gone - 1997 3.9 V8i Discovery - Burt
Post #507164 3rd Mar 2019 5:22pm
DrRob
Take it back??? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #507165 3rd Mar 2019 5:24pm
jakebullet64
Fair comment, just getting to the stage where I feel one thing gets fixed and it comes back with another issue.
Cheers
Jake 2003 Range Rover Vogue 4.4 on Gas
Post #507172 3rd Mar 2019 6:14pm
As it is all over the place on every corner, suggest follow the full calibration procedure from GAP (in the manual) .
Post #507176 3rd Mar 2019 6:35pm
Mulcher
England 2006 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
Check the height sensor on that wheel. They might have refitted it incorrectly– sometimes they can go “over-centre” which gives bad info. 2006MY 4.2 SC
BMW R1250 GSA Rallye TE
Triumph Tiger 1050 (sold)
1979 Pontiac Trans Am (sold)
Post #507202 3rd Mar 2019 8:57pm
Ian Donkin
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
If your IID Tool is the bluetooth version, it has a guided calibration option that would be worth running through; it's very easy to use and takes no more than 10 minutes.
If this doesn't correct your issue then as has been suggested, take it back to where it was 'fixed'.
Post #507351 4th Mar 2019 8:31pm
jakebullet64
Update
Hi there.. Just a quick update. The rear right sensor was held on with two cable ties. I've replaced this with RQH100030.
Now the eas is hard faulting, requiring the codes to be cleared by IID which is reporting 0x64 articulation validity fault.
The live data is now worse too, with the height now saying 290. See pic.
I've had the sensor on / off four times this afternoon, I've twirled the arm round, but it will only fit on one way. The figures change as they should, but once mounted it's reading way off.
I've been into the iid tool but can't find guided calibration anywhere.
Cheers for looking.
Jake
Post #507399 4th Mar 2019 10:48pm
Page 98 onwards of the iiDTool manual Evil or Very Mad .
Post #507402 4th Mar 2019 10:56pm
jakebullet64
Morning.
Just been out messing with the FF.
This is the only page I can find regarding adjusting individual corners.
There may be an underlying issue anyway?
I entered extended mode, no probs, but it wouldn't drop back to standard. The lights (on the console) continually flashed that it wanted to change but never reached the setting.
Also. Whilst in that menu, changing the height of the rear right caused the 'height' reading to go in the opposite direction for that corner. Big Cry
Anyone else had this?
Options;
battery disconnect and Update iid tool, then try again
Admit defeat and book it in somewhere. 2003 Range Rover Vogue 4.4 on Gas
Post #507434 5th Mar 2019 9:42am
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
Being a non tech and very stubborn, I have been fighting with the tool to, just untill the moment I remembered an expression on here " RTFM". I sat down behind the pc did some propper reading ( the manual is pritty simpel) and solved my problem. Mr. Green Have you looked at the calibration (that is not the height setting) I think it should read 185 as value.
Post #507438 5th Mar 2019 10:02am
as advised above, relax and read the manual,
https://www.fullfatrr.com/gallery/albums/u...lV3.00.pdf
Post #507439 5th Mar 2019 10:09am
jakebullet64
Afternoon chaps.
Further update. Battery disconnect done after
Deflated all the corners.
Updated the IIDTool to the latest firmware.
Faults cleared and then did the guided calibration.
Drove the missus to an appt then the eas has hard faulted again.
The settings have gone completely the opposite way.
Below is the car on the car park.
I think I'm making progress. Shocked 2003 Range Rover Vogue 4.4 on Gas
Post #507481 5th Mar 2019 5:24pm
that looks like its gone into extended mode...is the brass compressor vent clear??
Post #507483 5th Mar 2019 5:27pm
jakebullet64
Hi Stan.
Thanks for looking.
The little cone thing on the pump? Yes it's clear.
Pump seems to work well. Filled the reservoir up from deflated quite quickly.
Having lpg, the pump is in the OSR cubby. Not clogged with soundproofing or other fabric.
you think it's worth another crack at the guided calibration? 2003 Range Rover Vogue 4.4 on Gas
Post #507492 5th Mar 2019 6:11pm
certainly, i would run through the height modes several times and then re-check heights and adjust.
Post #507508 5th Mar 2019 7:12pm
