Home > Off Topic > Help me build my off road expedition trailer :) help needed
Charles89
United Kingdom 2014 Range Rover SVAutobiography SDV8 Scotia Grey
Ok so... I'm building an L405 Trailer, I have 8 20" wheels (L405) and I am struggling to find out what stub axxle I need to be able to use my 20" wheels... I know they are roughly 5x112 etc. But I can't seem to find stub axles to fit these wheels.. can any one help? Maybe I am searching for the wrong thing?
I am building it with air suspension and independent trailing arm suspension with it's own onboard battery, charged by a 13 pin caravan plug, this will also power the compressor and leveling valves for the trailer..
Appreciate any help
I should add it's unbraked single axle
Post #506862 1st Mar 2019 2:17pm
Rob99
I think all RR wheels are 5x120 PCD 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #506867 1st Mar 2019 2:32pm
Charles89
Yes you are correct.. mobile phone type O PCD 120..
My only options I think are a 4x100 stub axle and an adapter... but I'd prefer it to be a stub axle that is already 5x 120 Very Happy
Post #506902 1st Mar 2019 5:28pm
Rob99
You might have a bit more luck at a 5 stud axle from someone that supplies agricultural trailer parts. The ones I’ve seen all seem to be 5 or 6 stud. 2021 D350 Fifty Edition - Carpathian Grey
Post #506922 1st Mar 2019 7:53pm
fisha
Not be simpler using a rear axle setup from a td5 discovery (or P38 RR ) ? ... would be the same PCD for the wheels, track width etc. already compatible for air springs as they were a fitment to that vehicle ( as was the P38 ) so parts readily available.
Strip the diff and halfshafts out, calipers off etc, weight wouldn't be that bad. They go on ebay for around £150 ...
Realistically through ... unbraked ? thats going to limit you significantly weight wise surely ? a total limit of 750kg for the trailer would mean that self levelling would almost be hardly worth the complication. Your 4 wheels alone will rack up to almost 150kg, the trailer frame and body likely another 200kg (if not more )... so your already down for a load capacity of 400kg. How much is that really going to deflect the suspension such that you need levelling ... would springs not be easier, and reduce complication ? V8 or else ...
Post #507419 4th Mar 2019 10:53pm
p38arover
Australia
Stub axle?
Or hub?
Here in Oz, the 5 x 120 is as common as muck and easily purchased from any trailer supplier, auto parts supplier, or eBay. It's probably the most common trailer hub down here close followed by a Ford 5 stud pattern. You will need to match the bearings to the stub axle. Here, there are two groups - Holden bearings or Ford bearings (different sizes). That may apply up there. Have a look at the UK AL-KO catalogue. There may be something there. There certainly is in the Oz version of their catalogue.
It was/is used on a number of GM cars, e.g., the Holden Commodore. Maybe the Opel Commodore or some Vauxhalls use the same PCD Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #507424 5th Mar 2019 12:04am
andygts
VW transporter rear end may be worth a look, they have the same stud pattern
Or just use some adapters, theres many variants availabe.
I do agree with the 750kg weight issue though, you aren't going to have a huge capacity if you want to legally carry much more than a couple of hundred kilograms Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #507528 5th Mar 2019 8:34pm
p38arover
Australia
I was watching the Guy Martin Nürburgring episode and I'm sure he had RR wheels on the rear of his Transit. Transit hubs might be an option. See pic here:
https://cityx.co.uk/2018/10/local-drone-co...ed-record/ Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #508555 13th Mar 2019 11:39am
chugga90
Rear hubs on Guy’s transit were not ford items.
There is a fellow building Volkswagen transporter alike trailers who may sell suspension units with the right pcd?
Bill Blackmore was his name I think, google might be a way to locate him?
Post #508624 13th Mar 2019 8:05pm
p38arover
Australia
Aha! I've not taken much notice of Transits since I sold mine back in the 70s. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #508628 13th Mar 2019 9:00pm
chugga90
Must admit they are not my choice, but the pcd on transit wheels seems huge.
My involvement with transits ended in 90’s when I moved on from my first employer.
Post #508757 14th Mar 2019 8:32pm
