Home > Off Topic > Help me build my off road expedition trailer :) help needed |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1431 |
I think all RR wheels are 5x120 PCD 2021 D350 Fifty Edition - Carpathian Grey
1st Mar 2019 2:32pm |
Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268 |
Yes you are correct.. mobile phone type O PCD 120..
1st Mar 2019 5:28pm |
You might have a bit more luck at a 5 stud axle from someone that supplies agricultural trailer parts. The ones I’ve seen all seem to be 5 or 6 stud. 2021 D350 Fifty Edition - Carpathian Grey
1st Mar 2019 7:53pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1377 |
Not be simpler using a rear axle setup from a td5 discovery (or P38 RR ) ? ... would be the same PCD for the wheels, track width etc. already compatible for air springs as they were a fitment to that vehicle ( as was the P38 ) so parts readily available.
4th Mar 2019 10:53pm |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1536 |
Stub axle? Or hub? Here in Oz, the 5 x 120 is as common as muck and easily purchased from any trailer supplier, auto parts supplier, or eBay. It's probably the most common trailer hub down here close followed by a Ford 5 stud pattern. You will need to match the bearings to the stub axle. Here, there are two groups - Holden bearings or Ford bearings (different sizes). That may apply up there. Have a look at the UK AL-KO catalogue. There may be something there. There certainly is in the Oz version of their catalogue. It was/is used on a number of GM cars, e.g., the Holden Commodore. Maybe the Opel Commodore or some Vauxhalls use the same PCD Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
5th Mar 2019 12:04am |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 352 |
VW transporter rear end may be worth a look, they have the same stud pattern
5th Mar 2019 8:34pm |
I was watching the Guy Martin Nürburgring episode and I'm sure he had RR wheels on the rear of his Transit. Transit hubs might be an option. See pic here:
13th Mar 2019 11:39am |
chugga90 Member Since: 24 Jul 2015 Location: Chilterns Posts: 153 |
Rear hubs on Guy’s transit were not ford items.
13th Mar 2019 8:05pm |
Aha! I've not taken much notice of Transits since I sold mine back in the 70s. Ron B. VK2OTC
13th Mar 2019 9:00pm |
Must admit they are not my choice, but the pcd on transit wheels seems huge.
14th Mar 2019 8:32pm |
