Home > In Car Electronics (L405) > Wonky Heads Up Display
carlos50
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Hi all
Anyone else have a wonky heads up display on their screen when viewing from the drivers seat? Mine is clearly slowing to the right and the adjustment in the menu doesn't alter that. Is it possible to actually move the display inside the dash-top without complete disassembly of the dash area?
The picture was taken this morning behind my offices and the phone was level with the bottom of the instrument binnacle, you can see the front of the car at the bottom of the picture, its not quite as bad as it looks, the car was sloping slightly too but it is very obvious from the drivers seat so the picture gives a clear idea of what Im seeing.
Thanks
Carl
Post #506660 28th Feb 2019 1:23pm
my suspicions are that its not 'pointing' at the screen correctly...can you see if it can be aligned ..
Post #506670 28th Feb 2019 2:29pm
carlos50
Any guidance on the alignment will be greatly appreciated Rolling with laughter
Post #506672 28th Feb 2019 2:31pm
we dont have a L405 workshop manual and i suspect it might be a dealer job..
i have however looked in the L494 WM and couldnt see any info..
Post #506675 28th Feb 2019 2:37pm
ABAB
Have you tried adjusting the vertical position of the HU display on the windscreen - just to see if it helps correct what seems like a twist in the mechanism?
This problem is not something I’ve seen or experienced. 2016 SDV8 AB
Post #506685 28th Feb 2019 3:23pm
carlos50
Adjusting the height sorted it, strangely lowering the height too much made it slope as seen in the pictures, increasing the height too much made it slope the other way, it doesn't rise and lower level.
Its sorted for my driving position so that's the important thing, thanks for the advice everyone.
Post #506781 1st Mar 2019 8:25am
ABAB
Brilliant news, glad it worked.
That kind of thing out of alignment drives me nuts. 2016 SDV8 AB
Post #506900 1st Mar 2019 6:23pm
