![]() | Home > General > Venture Cam Holder |
Andpopse Member Since: 16 Oct 2010 Location: Bristol Posts: 100 ![]() ![]() ![]() |
Has anyone had the holder not able to stay in the closed / charge position. Mine will no longer close, is there a fix ?
Dogman Member Since: 10 Dec 2010 Location: UK Posts: 174 ![]() ![]() ![]() |
On the venture cam front, is it easy to retrofit the charging cradle?
AMD Member Since: 16 Jul 2010 Location: The South Posts: 811 ![]() ![]() |
The same happened to mine, fell down and never stayed up again. Dealer wanted over £300 to fit a new one but after a bit of shouting I got it done under approved warranty. Current MY2020
Any idea where I can get a replacement Venture Cam holder (cheaper than stealer) as I have a droopy one this morning |
I have just changed computers so no longer have Microcat. Can anybody look up the charging cradle part number on a 2006 Vogue SE Supercharged please? |
Come on Stan I know your there...... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35504 ![]() ![]() |
used the online microcat btw.. |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1668 ![]() ![]() |
Online Microcat doesn't show the supersession information though, does it? |
if i knew what that meant i would tell you.. |
Noun 1. supersession - act of replacing one person or thing by another especially one held to be superior
Thanks Scary problem is that part is £200 and another £200 ish to remove the dash to fix it in and who knows what problems that may cause....
clever solution gary.. |
