Home > General > Venture Cam Holder
Andpopse
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Venture Cam Holder
Has anyone had the holder not able to stay in the closed / charge position. Mine will no longer close, is there a fix ?
Cheers
Andy
Post #53382 7th Mar 2011 6:00pm
daveo
hi, i have had a few apart and came across this before, there is a small spring loaded clip that locks into place, the first one was the spring and the second one was the clip but we got away with super glue, its a bit of a fiddley job as you will need to dismantle the whole unit. just look or draw what way the springs go Exclamation or you will have a nightmare... V8 facelift Range Rover Autobiography 22" wheels.
Post #53394 7th Mar 2011 6:43pm
Dogman
On the venture cam front, is it easy to retrofit the charging cradle?
Oh and the next question, if the answer is yes, would be is there anywhere to get them apart from the stealers?
Post #53416 7th Mar 2011 8:20pm
AMD
The same happened to mine, fell down and never stayed up again. Dealer wanted over £300 to fit a new one but after a bit of shouting I got it done under approved warranty. Current MY2020
Gone: 1 x L405 and 2 x L322's
Post #53432 7th Mar 2011 10:17pm
Any idea where I can get a replacement Venture Cam holder (cheaper than stealer) as I have a droopy one this morning Crying or Very sad
Post #70281 28th Jun 2011 8:54am
I have just changed computers so no longer have Microcat. Can anybody look up the charging cradle part number on a 2006 Vogue SE Supercharged please?
Post #70283 28th Jun 2011 9:00am
Come on Stan I know your there...... Wink
Post #70285 28th Jun 2011 9:13am
you know me so well gary.. Laughing
Post #70286 28th Jun 2011 9:18am
used the online microcat btw..
Post #70287 28th Jun 2011 9:20am
Martin
Site Admin
Online Microcat doesn't show the supersession information though, does it?
Post #70288 28th Jun 2011 9:23am
if i knew what that meant i would tell you.. Laughing
Post #70289 28th Jun 2011 9:25am
mzplcg
Noun 1. supersession - act of replacing one person or thing by another especially one held to be superior
Dom. Thumbs Up
Post #70304 28th Jun 2011 10:40am
Laughing ..still none the wiser...
Post #70306 28th Jun 2011 10:43am
Thanks Scary problem is that part is £200 and another £200 ish to remove the dash to fix it in and who knows what problems that may cause....
SOLUTION:
If you add three "pairs" of these micro velcro pads to the back of the holder (not cam) with both backing off but velcro fused then push the cradle back into place and hold for a few seconds you get a perfect fix. Cradle clicks back and stays in place and when you pull down the velcro bond breaks and down it comes.
Venture Cam charges perfectly as the pads are very thin and the gap already there is is the same width as the pads. £1.79 against £400-500.....Phew..... Thumbs Up (Homebase)
Last edited by Gazellio @ Prestige Cars on 28th Jun 2011 11:35am. Edited 1 time in total
Post #70308 28th Jun 2011 11:08am
clever solution gary.. Thumbs Up
Post #70309 28th Jun 2011 11:26am
