Home > Technical (L322) > TD6 Fuel Pressure Sensor fault / help
miggit
Evening Chaps.....
...got a bit of a head scratcher...
My pals TD6 fuel pressure sensor broke and started to leak about 8 months ago, so it was replaced and normal service was resumed Smile
Last week it failed again, D'OH!
So it was replaced again and the fuel filter was changed too.... that set up lasted 3 days before leaking Shocked
Both sensors showed signs of fuel ingress into the part that the wires plug into... makes me think that they have failed internally, OR, the low pressure pumps are getting a little carried away and overdoing it a wee bit on the pressure front Shocked Shocked
Which when you think about all the posts that start with my car wont start and the low pressure pumps aren't pumping enough, makes it a real mistry.
Is there a pressure regulator / bleed off in the fuel line between the pumps and the filter? that might have failed? Or does the fuel pressure sensor actually do what it's title suggests and supposedly turn off the low pressure pumps if it all gets a bit too much?
Love to know if any body peeps has suffered the same, and how it was rectified....
We had a phone call with Dan the very nice parts man @ Duckworths today, which has resulted in a gen LR sensor and fuel filter being posted, after my pal remembered the combination to his wallet, it was a frightening final total.... I'd hate to bung them on the car and it blow it's top again, that would be a Big Cry moment! Yesterday I couldn't spell Engineer... Today I are one!
Post #504225 6th Feb 2019 11:44pm
cianfrinato
Italy 2006 Range Rover SE Td6 Zermatt Silver
Same problem.
Did you find a solution?
Thanks
Post #699105 30th Aug 2024 8:54am
Deano322
United Kingdom 2003 Range Rover HSE Td6 Oslo Blue
Hello,
I was having problems with the engine cutting out of not starting. Popped several pressure sensors at the fuel filter. Eventually replaced the in tank pump and it is much improved, no more pressure sensor failures.
Cheap pump, fuel gauge works between 1/4 and 3/4, you can guess how I found this out!
Thanks
Post #699139 30th Aug 2024 8:36pm
cianfrinato
Mine RR has not starting problems, just only sensor leaking.
Post #699140 30th Aug 2024 8:39pm
