Home > In Car Electronics (L322) > MOSTBUS Fibre Optic Signal Fault |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35435 |
have you tried this info from our wiki,
29th Jan 2019 2:19pm |
Bazzer79 Member Since: 26 Apr 2016 Location: Thames Ditton, Surrey Posts: 43 |
Stan - thanks for the link! I've already seen that thread and there is some useful information. Instead of making my own Loop, I'm going to buy one instead. However I am still unable to identify the different modules and work out how to remove necessary trim, so hopefully someone else can advise? |
30th Jan 2019 9:28am |
bottom left i think is the amp, next to that the tv tuner??..
30th Jan 2019 9:50am |
Thanks Stan!
30th Jan 2019 11:17am |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 |
It's in the wiki page
30th Jan 2019 11:20am |
the WM download link is also in the wiki bazzer... |
30th Jan 2019 12:49pm |
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299 |
I had exact same issue I had a leak coming from the gps aerial on the roof a common issue also check around rubber boot seal and the top right corner of seal also silicone up around the upper tailgate brackets that fix to the body water gets in here. I bet you it’s the bluetooth module just bypass that first if not it’s probably the TMC module good luck. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
30th Jan 2019 8:48pm |
Thanks for your advice Jaysta!
31st Jan 2019 10:23am |
Hi mate the TMC is on the most loop as are the following Main head unit touch screen , radio receiver behind the main head unit screen, CD player , rear entertainment module, TMC, TV , Amp, Bluetooth module. I bet you anything its the Nokia bluetooth module that's took the water ingress if so you can pick up a newer module off eBay they are better and an easy install to. You deffo need to catch the source of the leak and good old Land Rover thought it was excepable to issue customers with a water shredder in the electrical compartment to protect equipment but this didn't stop the leak.Check your spare wheel well also for water ingress another common fault. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
31st Jan 2019 10:46am |
also bazzer . look at the denso manual which shows the MOST components and can be downloaded from the wiki.. |
31st Jan 2019 11:46am |
Thanks Stan & Jaysta!
31st Jan 2019 12:25pm |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
The TMC module is on the bottom left side, the TV receiver module will be the one at the front in the middle and I believe the amp is behind it.
31st Jan 2019 12:49pm |
Yes check fuse 22 its for the TMC module. The amp is behind the TMC module and to the right of TMC module is the rear entertainment module the TV module is behind that. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
1st Feb 2019 11:03am |
Used a MOST bypass loop and diagnosed the Nokia Bluetooth module as the faulty unit. Ordered one off the bay at so waiting to install that. So glad to have the ICE back up and running. Due to the position of the module, I'm surprised it's prone to water damage?
5th Feb 2019 4:29pm |
