Home > In Car Electronics (L322) > MOSTBUS Fibre Optic Signal Fault
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
i've also been struggling with the frozen screen.
After a few days, went to check the fuse22 and it was blown. Replaced it and it blew immediately...
Then replaced it with a 30A fuse and it didn't blew up.
After that, i was able, using the bypass mode of the BT module, to recover all the functionalities of the screen without the BT capabilities.
The BT module, as far as i know, packed up... In truth, it smells a bit of burned electrics.
As far as I know, i have no water ingress anywhere. Everything seems dry.
Post #504064 5th Feb 2019 5:44pm
Bazzer79
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Barolo Black
Fitted the used bluetooth phone module that i picked up on ebay and system is working fine now. With regards to the water ingress, think I might of found the issue...........
Post #504817 11th Feb 2019 1:30pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Bazzer,
Whilst that won't help the bluetooth module usually sits higher than that!
Bushy Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #504818 11th Feb 2019 1:58pm
fin
For the future if anyone is reading this so I don’t open up a new thread, I had the exact same problem except for the fuses not blowing.
Since I thought the BT unit was fried I opened it up and found copper style green corrosion.
I cleaned this off with electrical contact cleaner from Halfords and a tooth brush (I was not careful as it wasn’t easy coming off) and everything worked perfectly, 99% of the corrosion came off and the unit worked fine.
Sorry didn’t take an after photo
Post #511082 5th Apr 2019 10:52pm
