Home > Maintenance & Mods (L405) > L405 DOOR SEAL
Charles89
United Kingdom 2014 Range Rover SVAutobiography SDV8 Scotia Grey
L405 DOOR SEAL
L405 Door seals, does anyone else have issues?
I can hear excessive wind noise on the driver side, and I can then pinch the door and shut together with my fingers and the noise almost 80% goes away... new seal or do I need to re-align my door etc?
Post #502068 19th Jan 2019 7:26am
SmokieRRFF
Australia 2015 Range Rover Vogue SE SDV8 Santorini Black
Hi,
I have the same issue on my 2015 L405 but only at speeds of 130-140km plus on EU roads. Shocked
My 2011 L322 also does it but at 100km/hr.
What I do is open the door, put the window down, stand between the car and the door and physically pull the top window pillar/frame inward toward the car (some force applied) and the wind noise goes away for about a 6 months.
Just one or 2-3 descent shoves seems to do the trick for me.
I have not yet been annoyed enough with the L405 to do the same.
My seals/rubbers look good on both vehicles.
Hope it helps.
Post #508827 15th Mar 2019 1:57pm
verydisco
This is probably what they would do at the dealership to sort it. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #508828 15th Mar 2019 2:01pm
Rossy01
United Kingdom 2015 Range Rover Autobiography SDV8 Santorini Black
I am having the same problem on mine, All four need replacing. They just don't seem to fit very well
Post #508892 16th Mar 2019 10:34am
Charles89
This really does my head in now.. there is about 5 or mode DB different when I pinch and squeeze the door in between my fingers, so it really is either the door twisted/deformed or the seals that are shot....
Post #531376 19th Oct 2019 5:21am
Get a 6' block of wood (like a pallet foot) and close it in your door around where your latch is... Now make 100% certain your window is open (as its double glazed and will crack!) now push some weight against the top frame of your door! Gently at first then apply more pressure, bit by bit and you'll feel the door frame give, a couple of mm at a time... Check the gap has gone and road test... If not enough, redo steps above until it fits properly Thumbs Up
Sounds harder than it is... Just remember, baby steps! Very Happy
Post #531390 19th Oct 2019 7:34am
Charles89
Hi Craig
I have done this as per your post and hopefully it will fix the issue 😊
I will report back and let you know if its sorted the issue
Post #531405 19th Oct 2019 9:27am
Post #531433 19th Oct 2019 12:53pm
Jase71
Australia 2017 Range Rover Vogue TDV6 Santorini Black
Charles89 wrote:
Hi Craig
Did this work Charles89? 2017 Range Rover Vogue V6 Diesel
2006 Range Rover Vogue V8 Diesel - gone
Post #582142 2nd Feb 2021 5:25pm
JCW
£75k+ to buy new and resorting to blocks of wood to bend doors into shape, love it!
Post #582146 2nd Feb 2021 5:40pm
supershuttle
I had a Mercedes with the same problem - the dealer fix was exactly the one Craig suggested. Geoff
Post #582160 2nd Feb 2021 7:23pm
stablemate
United Kingdom 2017 Range Rover Autobiography SDV8 Causeway Grey
Sorry to hijack the thread but does anyone have the part number for the door seal that runs around the drivers door? Mine has been ripped and damaged so ideally need to replace it. - Corris Grey 2017 Range Rover Autobiography SDV8
- Phoenix Orange 2017 Discovery Sport HSE Black SD4
Post #582163 2nd Feb 2021 7:53pm
