![]() | Home > Maintenance & Mods (L322) > ZF 8 speed gearbox megaflush |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1785 ![]() ![]() |
Oil has to cool from 90-ish degrees down to between 45-50
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 352 ![]() ![]() ![]() |
I had a drain, fill, new filter and sump yesterday as it happens as a hopefully proactive and preventative measure on my 5.0 S/C, while my truck was in with Brownchurch for it's MOT!
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4323 ![]() ![]() ![]() |
Paul - rough cost for that drain and refill ? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
I did mine a month or so back, pretty easy, got a pan off AUTODOC (something like £65 for a ZF one) and £19/l for gen ZF oil from my tyres.co.uk so cheaper DIY with gen stuff works out at about £190👍🏻 There is nothing that can't be fixed with a hammer😜😜
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2567 ![]() ![]() ![]() |
How much oil gets changed when the pan is dropped? I recently only collected 3L by draining the pan but intend replacing the pan c/w filter next time. |
Afraid I was lazy with this one as the car was at the garage anyway!
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3551 ![]() ![]() ![]() |
I've searched all the threads and expect to drop 5 litres removing the pan.
Expect about 5 litres, plan to get 6/7 so you have enough to put back in. I think where folks hanvent had that much out the thermostat must have been shut. There is nothing that can't be fixed with a hammer😜😜
Your only draining the sump, not the pipework too |
Mikey
bruno22rf Member Since: 08 Mar 2018 Location: milton keynes Posts: 69 ![]() ![]() ![]() |
I think my local specialist charges £260 all in for a mega flush - is that a good price? |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
ZF in Germany charges 620 Euros for a flush 2012 TDV8 Black Edition
With decent oil? With a Megaflush machine? Then yes ![]() 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
