Home > Technical (L322) > 4.4tdv8 power loss "restricted performance" SOLVED
Hoppo4.4tdv8
So after a month of trouble free driving the first problem has struck.
It felt a bit odd this morning a little gutless then at about 2k it would take off.
Now the odd thing is that it only seemed to do it from a rolling start it appeared to be fine from a stand still?
Anyway a little later on it dropped into limp. Max of about 25mph
Stopped and restarted all was well again
The codes come back with.
Egr A high
Turbo boost low pressure.
I'm guessing the egr is sticking open? Or I have a massive boost leak?
That sound about right?
Post #500935 8th Jan 2019 4:58pm
split inlet manifold hoses?
have a read here, bound to be something relating to yours,
https://www.fullfatrr.com/forum/topic44115.html
Post #500937 8th Jan 2019 5:05pm
Hoppo4.4tdv8
Interesting read looks like I'll be checking all the hoses tomorrow then.
Post #500942 8th Jan 2019 5:24pm
rjff
Search donut -some results below.
And check for the possible oil leak at the rear below the donut mount and clean the sensors..
https://www.fullfatrr.com/forum/topic48780.html (in this when moving the bits about, careful of items 3 & 3a)
https://www.fullfatrr.com/forum/topic35977.html?highlight=donut
https://www.fullfatrr.com/forum/topic44102.html?highlight=donut
every little helps!! Cheers
Richard
Gap IIDBT
Post #500948 8th Jan 2019 5:59pm
Hoppo4.4tdv8
Looks like I'm getting the spanners out tomorrow
Post #500954 8th Jan 2019 7:06pm
Hoppo4.4tdv8
Found it.
Broken egr pipe.
Clearly been bodged in the past and I can't get one for a few days.
117+vat is silly for a poxy pipe but hay to.
I've mig'd it up till the now one arrives
Post #501000 9th Jan 2019 1:06pm
Baltic Blue
I can’t just picture in my mind where that pipe fits.
Please can we have some pictures Thumbs Up
I can’t recall any previous similar failure being reported on a 4.4 tdV8.
Well spotted.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #501005 9th Jan 2019 1:50pm
Hoppo4.4tdv8
I'll take some more pics when I do the proper repair.
But for now the pipe is located under the cabin filter assembly. To the rear of the engine between the V. The round flex pipe fits to the top of the exhaust and this runs into a cast square flange that bolts into a manifold on the right hand rear of the engine.
When I started the car from cold there was noticeable smoke/ gasses leaking from the rear of the engine. As it warmed up this reduced so I'm guessing it's to do with the egr system?
However it did seem to be stopping the smaller turbo from providing any low down boost.
Now it's bodged back together it seems fine again.
Post #501006 9th Jan 2019 2:08pm
Baltic Blue
Thanks Hoppo Thumbs Up
Post #501007 9th Jan 2019 2:27pm
GGDR
Hoppo do you have an IIDTool?
If so, were you getting any error codes?
. Cheers, Greg
Post #501008 9th Jan 2019 2:46pm
GGDR
Sorry just read the top....
Ignore me.
. Cheers, Greg
Post #501009 9th Jan 2019 2:47pm
Hoppo4.4tdv8
I don't have that tool but I checked it with a snap on scanner.
I had codes for.
Egr A high temp
Turbo charger low pressure
Mass air low flow.
Post #501010 9th Jan 2019 2:49pm
GraemeS
The pipe supplies exhaust gas to the EGR valve/EGR cooler.
Post #501052 9th Jan 2019 8:14pm
Hoppo4.4tdv8
Would it throw errors if I just blanked it out
Post #501126 10th Jan 2019 2:57pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
My understanding is the EGR function is essential on DPF fitted cars as part of the regen process. So I don't think you can blank it assuming you have DPF fitted. 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #501127 10th Jan 2019 3:22pm
