Home > Technical (L322) > 4.4tdv8 power loss "restricted performance" SOLVED
GraemeS
Blanking the pipe without an ecm EGR-delete update will cause driveability issues because the ecm will detect that all air is entering via the MAFs when some should be entering via the EGR valve so the ecm will close the throttle butterfly on very slight over-run resulting in cutting engine output totally.
Post #501149 10th Jan 2019 7:48pm
