Home > Technical (L322) > Articulation validity fault
steve1
United Kingdom 2006 Range Rover HSE Td6 Bonatti Grey
Replaced both rear height sensors and rewired new plugs. Suspension still on stops and won't raise ,above fault registered on icarsoft scanner ,cleared fault but returns after driving short distance, any pointers??
Post #499552 24th Dec 2018 8:58am
you havnt by chance put the height sensors in back to front??
Post #499553 24th Dec 2018 9:05am
steve1
Don't think so as both plugs are facing upward, also if I turned one over the plug looks like it would foul on the chassis
Post #499557 24th Dec 2018 9:33am
i did a forum search and that was a possible cause the another was broken wiring..
Post #499558 24th Dec 2018 9:37am
steve1
I've searched also and can't come up with a definitive answer
Post #499559 24th Dec 2018 9:40am
steve1
Just read these values from icarsoft 930, front right voltage 2.85v height 0.038, front left voltage 41.86v, height 0.053
Rear right voltage 4.77v height 0.00 rear left voltage 0.85v height 1.404 height shown in inches
On ABS scan 0x005A temp system deactivation,
0x008A air suspension system CAN error message failed to clear DTC'S
front raises and lowers off switch but rear not moving at all,
Replaced both sensors and rewired new plugs rear was on its arse before changing parts.
Anyone help please!!!!
Post #499701 26th Dec 2018 3:32pm
petebowling
United Kingdom 2003 Range Rover Vogue SE Td6 Java Black
Inactive air suspension
I have the same problem replaced the two rear sensors and now will raise front fine but the rear gos up but not level
How can the sensors be wrong way up they only fit one way on the chassis can you get new wire loom or a repair kit for them as I am not sure if mine are. All ok.
Like you you clear the fault then mile down the road its back in inactive?
Post #499805 27th Dec 2018 6:27pm
steve1
You can get the plugs with wire tails from this site, look on shop on the home page that's where I got mine listed under connectors and adapters
Post #499855 28th Dec 2018 10:14am
petebowling
articulation validity fault
I had this on my l322 you could clear fault then it would be back a mile down the road.
I changed sensors and fitted a wiring repair kit as I thought there may be a break, in the end I had to bite the built and take it to the garage.
It was found to be one of the brackets that holds the sensor in place at the rear was bent and causing the fault £6.35 bracket they also soldered my joints instead of the crimped connectors.
worth checking.
Post #504234 7th Feb 2019 6:34am
andygts
My old range rover had a few height issues and I ended up having 4 new sensors although only 2 were dead, I was told that they work within a set tolerence of one and other, so if they all wear at the same rate and voltages shift etc they stay within that tolereance, introduce a brand new sensor and it then operates outside of the tolereance and the car doesn't like it.
i'm not 100% sure on the info but doing all 4 sensors fixed it. Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #504252 7th Feb 2019 9:13am
staffs964
United Kingdom 2003 Range Rover HSE Td6 Epsom Green
Autel Diagnosis Errors
My car is practically off-road most of the time or at least that’s the state of the roads here (BVI)
I have the same issues as everyone else I guess, ABS Error shows AS CAN error and the AS errors flip between Static Res or the Articulation error. These require clearing periodically, but rarely when on good roads.
I've used a service kit on the pump $35 and works great. And bought 4 OEM Height Sensors which I have yet to fit.
Some frustrating results below, but no-one mentioned (hope I have this right) that, the new sensors have to be calibrated measuring the distance between the hub center and bottom of wheel arch rim, directly above.
The heights seen in the diags can be ignored and used only to see the up or downward movement scale when adjusting (repeatedly checking the tape measure until all correct). Apparently once set using the tape measure to get all the heights right, this is saved as the calibration and will now articulate the resultant feedback. The diags will show heights all slightly different and can be ignored.
I’m going to do mine in the near future, using my Autel DS708, a tape measure and the settings below (thx Joe90). If anyone thinks I’m talking rubbish feel free to set me straight.
Cheers
Staffs964
British Virgin Islands
The only 2003 TD6 HSE in the territory.
Post #518512 14th Jun 2019 6:41pm
