![]() | Home > Technical (L322) > Articulation validity fault |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35490 ![]() ![]() |
you havnt by chance put the height sensors in back to front?? |
steve1 Member Since: 29 Jan 2018 Location: manchester Posts: 56 ![]() ![]() ![]() |
Don't think so as both plugs are facing upward, also if I turned one over the plug looks like it would foul on the chassis |
i did a forum search and that was a possible cause the another was broken wiring.. |
I've searched also and can't come up with a definitive answer |
Just read these values from icarsoft 930, front right voltage 2.85v height 0.038, front left voltage 41.86v, height 0.053
petebowling Member Since: 17 Jul 2018 Location: Thetford Posts: 20 ![]() ![]() ![]() |
I have the same problem replaced the two rear sensors and now will raise front fine but the rear gos up but not level
You can get the plugs with wire tails from this site, look on shop on the home page that's where I got mine listed under connectors and adapters |
I had this on my l322 you could clear fault then it would be back a mile down the road.
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 360 ![]() ![]() |
My old range rover had a few height issues and I ended up having 4 new sensors although only 2 were dead, I was told that they work within a set tolerence of one and other, so if they all wear at the same rate and voltages shift etc they stay within that tolereance, introduce a brand new sensor and it then operates outside of the tolereance and the car doesn't like it.
staffs964 Member Since: 21 May 2016 Location: Ontario, Canada. Posts: 10 ![]() ![]() ![]() |
My car is practically off-road most of the time or at least that’s the state of the roads here (BVI)
