Home > In Car Electronics (L322) > Rear View Camera 2006 working only on separate power supply?
Voguevague
Greece 2006 Range Rover Supercharged 4.2 SC V8 Santorini Black
Greetings, I am looking for some pointers here please.
I have a Supercharged 2006 L322 and although it has needed a few jobs doing to get more usable, everything that I have touched to date seems to be original, as in having 2006 part stickers in place. In the case of the fuse box even the original cellophane is still unmolested.
The Parking Aid had an issues with a broken wire which is now fixed and now I am tackling the not functioning Rear View Camera (Part Number: XVI 500180 PNP) and need some kind help and advice please.
I have removed the camera from the vehicle by the plug in the spoiler fed by a Red/Yellow and Brown wires, feeding the camera's Black and Red wiring, although with selecting reverse and engine running etc there is no 12 Volts to this point?! . I have also unplugged the coax type plug to remove camera and now refitted.
The camera worked less than 0.1% of the time in use and when it decided to fire up, there was no problem, so I suspected a loose intermittent connection, this was quickly found when splitting the camera body as to the plug being loose on the printed circuit board and fixed.
On re installation, I still have no image unless I power up the camera independently from a battery boost pack, then all is fine and working, so it looks like a no power feed issue remains.
I have checked as per various handbooks/manuals for a power feed;
Being:
Handbook: Rear Load Space Fuse Box position. Fuse Number 8.
Workshop Manual: (I am presuming that Fuse Number 12 in the AJB is the same thing?).
I am though failing to find any icon resembling a camera or a fuse?
So what remains; is that I now have a functioning repaired camera which I am failing to power from the vehicle, I cannot seem to locate the fuse and would like help on how to check the power feed, a wiring diagram would be useful too please.
Thanking you, great forum.
Keith.
Post #497765 6th Dec 2018 1:25pm
Voguevague
Someone must know?
Someone must know where the Reverse Camera is powered from, does anyone know where I can find a wiring diagram for it please for a 2006 Supercharged.
Appreciate your time and help.
Seasons Greetings!
Keith
Post #499129 19th Dec 2018 12:02pm
i'm sure if you read the 4 threads re reverse cameras in the wiki you will be able suss it out..
Post #499134 19th Dec 2018 12:16pm
Voguevague
With the greatest respect Stan, No I am confused, hence my second post.
The only wiring I see in the Wiki is for a 2001 model, would you be able to point me in the right direction please.
Keith
Post #499149 19th Dec 2018 1:11pm
have you read these?
Post #499162 19th Dec 2018 1:51pm
Voguevague
Thank you Stan, I did read those. Perhaps the main question is where do the Yellow/Red and Brown go back to (as in attached photo), as they are dead under all conditions and I would like to check why.
Black and Red which attach to camera are cut for testing purposes only.
Keith.
Post #499167 19th Dec 2018 2:13pm
ivanzvara
Slovakia 2007 Range Rover Vogue TDV8 Buckingham Blue
I would like to know whether you managed to find an answer to your question, where the red/yellow and brown cable feed from. This is my issue, too.
Post #545797 2nd Mar 2020 2:46pm
JDGeorgia
United States 2006 Range Rover HSE 4.4 V8 Buckingham Blue
I'm curious if you ever got this sorted?
I am having the same issue. I have futzed around with the rear view camera for the 11 years that I have owned it. I think somewhere along the line - I blew something, but cant seem to find where.
Col Reb was a March 2006 build. He had the kitchen sink thrown at him.
My Owner's manual may be 2005, I think the rear fuse panel is 2006 or 2007.
The owner's manual shows Position 8 as empty, but I have a 20Amp fuse in there?!?!?
Cheapo cam off eBay works if I power directly from the big red terminal in the 'boot', but not by switching into reverse. 2006 L322 HSE LUX 4.4NA Jag V8 Buckingham Blue/Ivory - 'Col Reb'
Rolled Yahtzee Aug 2023 222,222Miles
2016 L405 HSE TD6. Santorini Black over Almond. - 'Donna the Diesel'
Only L405 IN THE KNOWN UNIVERSE with an L494 Shift Lever Fitted!
97K at purchase Sept of 2023
Post #675349 11th Oct 2023 8:16pm
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Maybe this will help
David Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #675362 11th Oct 2023 11:15pm
JDGeorgia
I probably way underthought this...
But I bought a cheap camera off ebay. The power in the top of the tailgate (original Cam) is deader 'n a doornail...
I initially ran a wire from the reverse lights in the lower tailgate up through the right rear ?D? pillar.
Worked like a charm with the truck off... not so much with it turned on.
Found some 'clean' switched power in the 'boot' and added a little programable timer to the circuit.
Reverse lights from tailgate are the signal, relay flips on the clean power to the camera and after I leave Reverse - the timer kicks on and the cam is powered for 90 seconds...
First time having a backup cam in Col Reb during my 11 year ownership... 2006 L322 HSE LUX 4.4NA Jag V8 Buckingham Blue/Ivory - 'Col Reb'
Post #678114 16th Nov 2023 9:56pm
