![]() | Home > In Car Electronics (L322) > Rear View Camera 2006 working only on separate power supply? |
Voguevague Member Since: 01 Apr 2018 Location: Athens Posts: 17 ![]() ![]() ![]() |
Someone must know where the Reverse Camera is powered from, does anyone know where I can find a wiring diagram for it please for a 2006 Supercharged.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35629 ![]() ![]() |
i'm sure if you read the 4 threads re reverse cameras in the wiki you will be able suss it out.. |
With the greatest respect Stan, No I am confused, hence my second post.
have you read these?
Thank you Stan, I did read those. Perhaps the main question is where do the Yellow/Red and Brown go back to (as in attached photo), as they are dead under all conditions and I would like to check why. Black and Red which attach to camera are cut for testing purposes only. Keith. |
ivanzvara Member Since: 02 Mar 2020 Location: Bratislava Posts: 1 ![]() ![]() ![]() |
I would like to know whether you managed to find an answer to your question, where the red/yellow and brown cable feed from. This is my issue, too. |
JDGeorgia Member Since: 11 Oct 2023 Location: Atlanta GA Posts: 159 ![]() ![]() ![]() |
I'm curious if you ever got this sorted?
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 606 ![]() ![]() ![]() |
Maybe this will help
I probably way underthought this...
![]() Found some 'clean' switched power in the 'boot' and added a little programable timer to the circuit. Reverse lights from tailgate are the signal, relay flips on the clean power to the camera and after I leave Reverse - the timer kicks on and the cam is powered for 90 seconds... First time having a backup cam in Col Reb during my 11 year ownership... 2006 L322 HSE LUX 4.4NA Jag V8 Buckingham Blue/Ivory - 'Col Reb' Rolled Yahtzee Aug 2023 222,222Miles 2016 L405 HSE TD6. Santorini Black over Almond. - 'Donna the Diesel' Only L405 IN THE KNOWN UNIVERSE with an L494 Shift Lever Fitted! 97K at purchase Sept of 2023 |
