Home > Technical (L322) > Yaw rate sensor, Open circuit |
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 |
I have a fault “Yaw rate sensor open circuit”
5th Dec 2018 7:50pm |
Replaced a Coca Cola sticky Yaw rate sensor and still had this problem!
11th Dec 2018 10:39am |
annette Member Since: 07 Nov 2018 Location: Tilarán Posts: 30 |
thank you I will check this next time another patient comes in.. Had the sensor out in this one as well, removed biscuits and chocolate but no joy |
12th Dec 2018 10:03pm |
Which faults are you getting? I’ve been through a lot on this one |
13th Dec 2018 1:21pm |
It is an early one, I get Can-bus errors on the ABS and supension.. but they display in another format.
13th Dec 2018 3:58pm |
I’m pretty sure that’s a steering angle sensor fault.
16th Dec 2018 7:12am |
Norway Member Since: 09 Dec 2012 Location: Hvik Posts: 123 |
How did this end. -03V td6
15th Feb 2019 11:59am |
Omg, I have to try that tomorrow. Cheers |
15th Feb 2019 7:39pm |
