![]() | Home > Maintenance & Mods (L322) > Battery drain |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6416 ![]() ![]() |
Did you try a search for "battery drain" ??
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 732 ![]() ![]() ![]() |
Dont think there's enough years left on planet Earth to read up on battery drain issues on a FFRR |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8687 ![]() ![]() ![]() |
Battery voltage when running?
Does seem to die too quickly to be a drain? When my FSR failed (had 2 on my FF now in 10 years of ownership) it used to drain over a matter of 5-7 days, certainly not a few hours? |
Fraynizzle Member Since: 27 Apr 2015 Location: Essex Posts: 111 ![]() ![]() ![]() |
the drain i had on the bluetooth module meant it was more often than not too low to start the car the next day. |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
I would check charge voltage with engine running is 14 volts plus.
what did it do when you tried to start it after leaving it for 3 hours? click only, nothing, turned over slowly etc?
