Home > Maintenance & Mods (L322) > Battery drain |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Did you try a search for "battery drain" ??
2nd Dec 2018 6:18pm |
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 728 |
Dont think there's enough years left on planet Earth to read up on battery drain issues on a FFRR |
6th Dec 2018 7:28pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8506 |
Battery voltage when running?
6th Dec 2018 8:11pm |
Does seem to die too quickly to be a drain? When my FSR failed (had 2 on my FF now in 10 years of ownership) it used to drain over a matter of 5-7 days, certainly not a few hours? |
6th Dec 2018 9:22pm |
Fraynizzle Member Since: 27 Apr 2015 Location: Essex Posts: 111 |
the drain i had on the bluetooth module meant it was more often than not too low to start the car the next day. |
7th Dec 2018 11:40am |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
I would check charge voltage with engine running is 14 volts plus.
11th Dec 2018 11:27pm |
what did it do when you tried to start it after leaving it for 3 hours? click only, nothing, turned over slowly etc?
12th Dec 2018 4:17pm |
