![]() | Home > Technical (L322) > FBH |
Worth noting is that the FBH will cut out if your battery drops below 11.5V so if your battery isnt healthy it will shut down after a few minutes - this is happening on mine atm. I verified this by plugging the charger in and it then ran full cycle.
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1750 ![]() ![]() ![]() |
Cool
I've found it's only noticeable after its been running for the full time. 30 mins is the max it will run for.
Hmmm. Not seen anything in there but will have another look. Thanks Ash
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
So, can I just get this right then- even though I DON'T have the remote, the FBH will still heat the interior on cold mornings? Just a case of setting it in the OBC?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35529 ![]() ![]() |
![]() Y. O. L. O. . |
