Home > Technical (L322) > Instrument gauges intermittent L322 '04
Richycsurfer
United Kingdom 2004 Range Rover Vogue Td6 Bonatti Grey
Hi everyone,
I've recently bought a l322 td6 which has intermittent instrument gauges. They could work all day, turn off at some point or not come on in the morning. It is the fuel, revs, speedo and temperature analogue gauges. The fuel reads low with the light on. No warning lights on. They can come back on with a ignition off and on reset or need longer. The rev counter seems to bounce a little when started and then settle at 0. Has anyone encountered this before? I've had a search but struggling to find much help. Thanks for any advice!
Post #495880 18th Nov 2018 11:25am
Richycsurfer
Has nobody come across this? It seems to happen maybe once in ever 5 starts and takes stopping and leaving the car for a bit to forget it doesn't want to work. My alternator is putting out 14.2V so the battery is assumed ok but maybe it could do with a proper test?
Post #496040 20th Nov 2018 9:44am
try a forum search ...
Post #496042 20th Nov 2018 9:49am
Richycsurfer
It was my first move - nobody i can find seems to have the same things dying on the dash (just gauges)
Post #496064 20th Nov 2018 12:20pm
crowebeard
United Kingdom 2012 Range Rover Westminster 4.4 V8 Orkney Grey
While my dials are OK, the digital display used to suffer from a similar fault, it was either on or off and nothing I did made any difference to it and it wasn't just the standard pixel issue either. It's now permanently off.
I phoned up a couple of companies that specialise in repairing instrument clusters, and was told that the 2004 year are notorious for components failing in the cluster, so now I need to extract the cluster and send it off in the next couple of weeks to be refurbed.
It maybe that the analogue dials suffer a similar problem, probably best give a repair company a quick call to see if they have seen it before. I will be using Cartronix, but there are plenty about. David
2012 Range Rover Westminster 4.4TDV8
2004 Range Rover Vogue 4.4 V8 (LPG) (Not quite gone)
2021 Mazda CX-5
2003 Porsche Boxster
Post #496084 20th Nov 2018 3:28pm
fisha
Do the general backlights work or do they flicker in time with the dials dying to zero. V8 or else ...
Post #496099 20th Nov 2018 6:25pm
Richycsurfer
No flashing it appears. It happened this morning working for around 5 seconds and then died. The speedo, temp and fuel all die instantly but the revs pulse while dropping.
Post #496152 21st Nov 2018 8:12am
Richycsurfer
So..gently pulsating fuel, revs and water but flaccid speedo.
I've just spoken to cartronix who say it isn't something they would be able to work with. Presumably indicating a fault elsewhere?
Post #496160 21st Nov 2018 9:25am
fisha
Hmm interesting.
It smacks of a loose connection or something gone within the cluster to me which is common to the dial gauges. The gauge signals appear to be fed by the blue connector into the back of the cluster. The power appears to come from the other one ( white connector I think ).
If it were something like a poor external earth in general from the wiring, then given that the power / earthing comes from the white connector, you would expect ALL the lights in the cluster and similar to flicker like the gauges. ... they don't appear to do that.
Which leaves the common factor being the gauge signals ... and looking at the wiring, the only commonality between them is the the instrument cluster itself. Its not unheard of for the board on the cluster to fail, or at least components of it such as capacitors ( google search brings this up ).
Have you tried these tests ?
https://www.landyzone.co.uk/land-rover/hid...es.268250/
The wiring diagrams ...
 V8 or else ...
Post #496225 21st Nov 2018 7:04pm
Richycsurfer
Thanks for the thoughts and reply. Not great news, then.
I will try the 'self test' check tomorrow, is that the test you mean? I've just realised maybe my headlight 'on' light didn't appear to be illuminated but I had auto headlights on which were on. I'll check this tomorrow once it's all working again and see if it comes on then. Would this help any diagnosis?
Post #496246 21st Nov 2018 10:10pm
fisha
the self test stuff should flick the guages through their whole range of motion and back to zero. its a long time since i did mine.
Quick search found this:
 V8 or else ...
Post #496252 21st Nov 2018 11:04pm
Mark_L
United Kingdom 2005 Range Rover Vogue SE Td6 Barolo Black
Hi,
I have 2005 Vogue SE and have recently started experiencing exactly the same problems as Richycsurfer with the analogue dials not working more often than not. My problem is exactly the same as described in this post.
I was wondering if you found the root cause of the problem and what the solution was? Thanks.
Post #533652 9th Nov 2019 6:03pm
Richycsurfer
Unfortunately I didn't yet... I've lived with it since however did have some advice to check the earth to the gauges, something which I havnt yet done
. I also heard I could swap out the gauges for another set without much problem?
Post #533665 9th Nov 2019 8:10pm
Mark_L
Thanks for the response.
I am thinking of getting a GPS speedometer as I pass through a lot of speed cameras each day and can't trust the dials anymore.
If I have any luck finding a solution I will let you know.
Post #533771 10th Nov 2019 10:04pm
EJL
United Kingdom 2005 Range Rover Vogue SE Td6 Baltic Blue
Sorry to resurrect an old thread but did you ever get to the bottom of this? My fathers 2005 FFRR Vogue SE has recently started doing the exact same thing.
Post #556916 8th Jun 2020 1:06pm
