Home > In Car Electronics (L322) > Secret screen access
Rambles
I occasionally see mention of a secret screen menu
And of the magic code 753
Press near the top in the middle whilst in main menu
Does nothing on my MY11
Any ideas please?
Post #495866 18th Nov 2018 9:40am
nothing worth seeing there tbh...there are youtube videos on this and some stuff in the wiki..
Post #495893 18th Nov 2018 1:52pm
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
On home screen, push top of screen in middle 5s, then press nav hard key and keep pressed 5s, pin keypad will then come up Cheers
James
Post #495931 18th Nov 2018 7:10pm
It does work, but as Stan says it’s a bit pointless...... unless you get good tv reception cos you can set the tv to show while moving in a forwards direction..... Whistle but it’s dangerous and illegal so don’t do that...... Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #495943 18th Nov 2018 8:48pm
160dmb
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
I used it to keep the rear view camera on when I was towing a car on a trailer sometimes - good for that. Does it work on an L405? 2016 (L405) Autobiography in Black with Ivory - for ULEZ
2014 (L405) VSE in Black with Ivory
2011 (L322) VSE in Black with Ivory
2005 (3.2 V6) Porsche Cayenne in Black with Savanna
1999 (P38) VSE in Burgundy (?) with Sand
Post #495983 19th Nov 2018 12:10pm
JST
^^^ likewise with livestock.
shows you alt output if you wanted a quick check
apart from that not much going on there of use to me. Cheers
James
Post #496012 19th Nov 2018 6:51pm
andygts
another + 1
I always use it when towing to put the rear camera on Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #496080 20th Nov 2018 2:47pm
