Home > Technical (L322) > T91R remote.
Simon123
Wales 2010 Range Rover Autobiography TDV8 Santorini Black
T91R remote.
Hi all,
Looking for some clarification!! I own a 2010 (revised) 3.6tdv8 autobiography and the fbh works fine manually, has a transmitter fitted, though when I purchased came without the remote. I've asked previously if the T91R is compatible and the consensus was a yes so went ahead and purchased one from eBay. I've tried multiple times to pair the remote unsuccessfully ( the fuse route then disconnecting the power lead to the transmitter and also changing battery). Sent a query to the seller who informs me that this remote is only for the 405, even though other sellers advertise for L322 etc. The remote is marked Land Rover (not Range Rover) and the on switch is marked with a heating element and fan sign rather than on. Am a little confused and wonder if someone could kindly point me in the direction of where I could buy a compatible remote???? Or is it the case that perhaps the remote is faulty, didn't come with proper packaging etc.
Many thanks
Post #495277 12th Nov 2018 7:58am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
From what I can tell, and it's a bit of a mystery, the fob you need should have 'on' and 'off' so I think you have the wrong one Sad Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #495286 12th Nov 2018 9:44am
Simon123
Only ones I can find with an on and off button are specifically for the 405 !! Am really confused !!!!! Question
Post #495290 12th Nov 2018 9:55am
TomCobbly
This is the one you need...
 2011 4.4 TDV8 Vogue SE
1993 Discovery 1 3.5 V8i
Post #495295 12th Nov 2018 10:10am
Simon123
Thanks for that. Any ideas where I can get one or point me to a link
Post #495316 12th Nov 2018 11:41am
TomCobbly
I got mine from ebay a couple of years ago. I've had a quick look and can't see any on there at the moment unfortunately. Not sure where else you might get one other than a main dealer I'm afraid. 2011 4.4 TDV8 Vogue SE
Post #495321 12th Nov 2018 12:09pm
TomCobbly
OOh just spotted this...
https://www.ebay.co.uk/itm/LAND-ROVER-WEBA...:rk:2:pf:0 2011 4.4 TDV8 Vogue SE
Post #495322 12th Nov 2018 12:11pm
Simon123
Ok , thanks for that
Post #495323 12th Nov 2018 12:11pm
Simon123
Unfortunately looks the same as I've got !! No switch marked on instead heater/ fan sign. Was told these were not compatible
Post #495324 12th Nov 2018 12:15pm
TomCobbly
Or this cheaper one. They look the same as mine but the on button has a different picture
https://www.ebay.co.uk/itm/Genuine-Land-Ro...rk:20:pf:0 2011 4.4 TDV8 Vogue SE
Post #495325 12th Nov 2018 12:15pm
AJGalaxy2012
I got one from there but cant get it to work #8o( BMW i3 Electric Car
2006 VW Touareg 3.0 TDi V6
Post #495326 12th Nov 2018 12:16pm
TomCobbly
Is the battery good on your one? What happens when you try to sync it to the T91? 2011 4.4 TDV8 Vogue SE
Post #495327 12th Nov 2018 12:17pm
Simon123
Have changed the battery for a new one but just flashes 8 times, on or off. The transmitter in vehicle is marked T91R
Post #495328 12th Nov 2018 12:23pm
TomCobbly
Did you keep the on button pressed as you connected the power back on the T91R receiver? 2011 4.4 TDV8 Vogue SE
Post #495330 12th Nov 2018 12:39pm
Simon123
No, pressed the off button, was that wrong ??
Post #495331 12th Nov 2018 12:42pm
