Home > Technical (L322) > T91R remote.
TomCobbly
Sorry I think I got that wrong. This is what I did from an earlier thread.
Quote:
The receiver is located behind the rear offside (RHS) access panel in the boot. It has two plug-in connections and you need to remove the one with three wires coming from it. The plug just pulls out but it can be quite a tight fit. Leave it out for about 30 seconds then plug it back in and press the off button on your remote within five seconds of replacing the plug. I'm not sure if this is the official method but it worked first time for me
 2011 4.4 TDV8 Vogue SE
1993 Discovery 1 3.5 V8i
Post #495332 12th Nov 2018 12:42pm
Simon123
Wales 2010 Range Rover Autobiography TDV8 Santorini Black
Yes I did that quite a few times and no joy, just flashes 8 times. The confusing thing is am not sure I have the right remote now !! Some say the t91r remote is ok and some not, so really is confusing . Apart from VW etc T91r remotes, the Land Rover ones don't seem to have an on marked button just the heating element /fan sign
Post #495334 12th Nov 2018 12:50pm
TomCobbly
The sign is just painted on but everything else looks Identical. I would have thought it would be fine. I wonder if the R after T91 is significant.
What does the label on your receiver say? Just checked mine and it says T91... no "R"
Here is one with an on button but he wants £250 for it - is he serious?
https://www.ebay.co.uk/itm/LAND-ROVER-RANG...rk:23:pf:0
Cheaper to buy a T91R receiver...
https://www.ebay.co.uk/itm/LAND-RANGE-ROVE...rk:25:pf:0 2011 4.4 TDV8 Vogue SE
Post #495335 12th Nov 2018 1:02pm
Simon123
Just checked the transmitter and like yours says T91. As you say that seller on eBay is having a laugh !!!!!!!!!
Post #495346 12th Nov 2018 1:38pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Simon123 -- one just gone up for sale on here! Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #495352 12th Nov 2018 2:12pm
TomCobbly
Where? 2011 4.4 TDV8 Vogue SE
Post #495357 12th Nov 2018 2:23pm
TomCobbly
You could try Webasto direct.
https://www.webasto.com/gb/markets-product...start-t91/ 2011 4.4 TDV8 Vogue SE
Post #495358 12th Nov 2018 2:23pm
Bushy30
Tom,
In the 'for sale' section !
http://www.fullfatrr.com/forum/topic49280.html
Bushy Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #495359 12th Nov 2018 2:34pm
TomCobbly
Excellent - Looks like Simon is sorted 2011 4.4 TDV8 Vogue SE
Post #495360 12th Nov 2018 2:38pm
Simon123
Yes very much so and thanks for keeping an eye out for me !!
Cheers
Post #495362 12th Nov 2018 2:40pm
