![]() | Home > Maintenance & Mods (L322) > Lower front grille on 2010 range rover vogue |
DBB Member Since: 18 Mar 2016 Location: United States Posts: 42 ![]() ![]() |
Unfortunately it will not be a direct fit. That lower grille pictured is intended for the design pack bumper. |
Tomo676 Member Since: 07 Aug 2018 Location: Aberdare, South Wales. Posts: 51 ![]() ![]() ![]() |
Thanks for the reply, can it be modified to fit ? or is it easier to change the bumper ? |
This isn’t a common modification, but if you already have the part, give it a try. Both bumpers have a center under tray mounted using plastic pins. Your ideal scenario would be that the pin holes are in the same location. You would most likely have to remove the black horizontal trim from the current bumper for this piece to sit flush. Then you still have the issue of the corners of the design pack under tray being rounded while the standard bumper opening is square.
Thanks for the help, decided too live with it as it is, less hassle. Thanks again. |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16312 ![]() ![]() ![]() |
Would fit this type of bumper below sir |
