Home > Maintenance & Mods (L322) > Lower front grille on 2010 range rover vogue
Tomo676
United Kingdom 2010 Range Rover Vogue TDV8 Ipanema Sand
Can someone please tell me if this grille will fit my motor please ?
Post #494938 7th Nov 2018 8:47pm
DBB
United States
Unfortunately it will not be a direct fit. That lower grille pictured is intended for the design pack bumper.
Post #494958 7th Nov 2018 10:22pm
Tomo676
Thanks for the reply, can it be modified to fit ? or is it easier to change the bumper ?
Post #494995 8th Nov 2018 12:10pm
DBB
United States
This isn’t a common modification, but if you already have the part, give it a try. Both bumpers have a center under tray mounted using plastic pins. Your ideal scenario would be that the pin holes are in the same location. You would most likely have to remove the black horizontal trim from the current bumper for this piece to sit flush. Then you still have the issue of the corners of the design pack under tray being rounded while the standard bumper opening is square.
The most plug and play solution is to replace the bumper with the design pack model.
Post #495011 8th Nov 2018 3:08pm
Tomo676
Thanks for the help, decided too live with it as it is, less hassle. Thanks again.
Post #495023 8th Nov 2018 3:54pm
Would fit this type of bumper below sir Thumbs Up
Post #495053 8th Nov 2018 11:00pm
