Home > Wheels & Tyres > improving Ride comfort L322
John1000
Hi, I am looking to improve ride comfort on road in a 2011 SC. I thought about moving to a 235 55 r20 tire (same diameter as OEM) or 255 55 r20, but some people just had rubber issues. Anyone could please recommend a tire that will fit without mods? I ws thinkin 235/255 55 r20. Another option is to reduce psi. What would be the best psi? Any other ideas? thanks in advance
Post #494476 2nd Nov 2018 10:23pm
I’m amazed that you think the ride comfort isn’t good.
What tyres do you have on the car just now? Got - 2017 SDV8 Autobiography in Loire Blue
Post #494478 2nd Nov 2018 11:10pm
quavey
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
235/55/20 is a smaller diameter remember the profile, 55, is a percentage of the tread width, 235.
In this case you are reducing the over diameter by almost an inch 2005 E60 M5
2006 L322 4.2 SC
2020 Tesla Model S Long Range
2004 L322 4.4 Vogue, 2019 NP300 Navara, 2016 NP300 Navara, 2002 L322 4.4 HSE, 2006 (MY07) L322 S/C ,2001 330Ci Sport Track Car, 2005 650i Coupe, 2001 P38 Vogue, 2003 530i Sport Touring, 1999 P38 4.6 HSE, 2002 E39 M5, 1995 300zx TT Slicktop, 1997 M3 Evo, 1992 300zx TT Targa, 1998 323i Coupe
Post #494481 2nd Nov 2018 11:33pm
John1000
Hi, ride is good but would like to improve it as much as I can. I am using the continentals crosscontact...car is a 2011 SC...thanks
Post #495037 8th Nov 2018 7:00pm
John1000
yes, you are right. I should go for 255 55 r20, I do not think 275 55 r20 will work
thanks
Post #495038 8th Nov 2018 7:01pm
Lester Burnham
How old are the existing tires? They degrade so slowly you don't realise how good a new set can feel until you slap them on. This might be as much a problem as tyre size.
Post #495041 8th Nov 2018 7:22pm
Ticketyboo Too
Ireland 2010 Range Rover Vogue SE TDV8 Zermatt Silver
I have the Vogue SE 2010 TDV8 and my last two sets have been Michelin Latitude Sport 3 255/50 R20, okay not the SC, but the ride comfort has been excellent, grip superb esp in the wet and I get good wear (I rotate front-back every 3-5K miles), so much better than the Conti boots that were on when I got her.
Now looking to get a set of good winter boots as we live high up and this past Feb we were snowed in for 5 days, the road tyres just no good in -12oC and dry or compacted snow. FF MY2010 3.6 tdV8 VogueSE
Post #495058 9th Nov 2018 8:52am
john, one option to improve comfort is to reduce the tyre pressures slightly by a couple of psi...
Post #495059 9th Nov 2018 9:21am
John1000
Hi Lester, they are from Nov 2016, they have 22,000 miles, thx
Post #495079 9th Nov 2018 11:45am
John1000
thanks Stan, will try that
Post #495084 9th Nov 2018 12:33pm
160dmb
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
I bought a set of 255/55 20 Michelin Diamris Sport for my previous L322.
Improved the ride no end and absolutely no downsides and not even a thought of rubbing even at access height.
There are many threads on this virtually all positive, the only downside is that I like the look of Pirelli Scorpions but I spend far more time inside driving than outside looking at the tread blocks! 2016 (L405) Autobiography in Black with Ivory - for ULEZ
2014 (L405) VSE in Black with Ivory
2011 (L322) VSE in Black with Ivory
2005 (3.2 V6) Porsche Cayenne in Black with Savanna
1999 (P38) VSE in Burgundy (?) with Sand
Post #498087 10th Dec 2018 11:31am
Paul thornton
I think most people go for the L405 size which is 255 55 20 as they have a larger side wall hence improving comfort.
Post #498120 10th Dec 2018 5:06pm
Vogue
There is absolutely nothing wrong with the ride comfort of an L322 running the correct tyres at the correct pressures Thumbs Up 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #498152 10th Dec 2018 9:37pm
