![]() | Home > Maintenance & Mods (L322) > 4.4 TDV8 Belt tensioner replacement |
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 147 ![]() ![]() ![]() |
Any suggestions where I can source the crankshaft pully,LR022805?Pretty price at JLR!! 2012 TDV8 Vogue SE 4.4 |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 813 ![]() ![]() |
Is there a part number for the belt please?
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
She is obviously incorrect.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4318 ![]() ![]() ![]() |
I assume you are booking it into Harwoods? You’d save a load of cash by using an independent to do it. Just had mine fitted for around £150. I’d bet Harwoods will be at least double given their hourly rate. Where are your based? We can recommend some places for you. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 ![]() ![]() ![]() |
Hi,
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2561 ![]() ![]() ![]() |
Thanks for the tips John. |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
i hit some deep water the other night now i have a squeaky engine sounds to me like a belt pully is probably the guilty party. so if i am going to change one part i think i will order up belts pully's and tensioner do the lot in one hit.
Right then!!
Mike220 Member Since: 21 Sep 2020 Location: uk Posts: 116 ![]() ![]() |
Thanks Jayk69, keen to see how you get on as I see this job in my future probably 2011 Vogue SE Tdv8 FFRR |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1266 ![]() ![]() ![]() |
Good luck. About to do mine. Thinking of changing the water pump at the same time so I know ALL the bearings are good then. Did you go for genuine parts? |
No not all genuine i went for a OEM part for tensioner from Rimmer Bros as it is a big saving and has 2 year warranty and the last pully i got from Advanced Factors as it was £96 on Rimmers but £36 from AF for the same part no (Original)
Thanks for your reply mate. I might go for a genuine tensioner and pattern for the rest then. |
After Kevinp's comment i have decided to change the water pump as well.
Looking forward to see how you get on mate. |
