![]() | Home > In Car Electronics (L322) > Cd player |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 904 ![]() ![]() ![]() |
It might be better/cheaper to fit an Intravee unit and move over to MP3/iPod music instead?
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 474 ![]() ![]() ![]() |
Unfortunately the Intravee only works on the BMW non touchscreen models. The later (2006) will need a diff rent method for iPod |
You need the Audio Connectivity Module - VPLME0004
clemenz Member Since: 13 Sep 2014 Location: Graz Posts: 183 ![]() ![]() ![]() |
Also possible to replace the laser unit inside the cd changer |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
Or get the Bluetooth receiver that goes through the aux port for £10, ive used one a few years no issues, wires hidden in box and right angle extension into the cubby box where it joins the remote wire that sits in front of the gear stick.
Neat! I've ordered one from Amazon - should be here tomorrow. My current solution is hard wired but doesn't allow me to stream from my phone - so MANY THANKS for the inspiration for this!!! Land Rover Addict
Forgot to add i use this for the extension so i can close the rear lid on the aux port, i drilled a small hole and pushed it through and that's the best place as it misses the wiring and box under the ports,i left most of the cable under the cubby box and pushed the receiver wire into it and hid it under the box |
Gyre8 Member Since: 14 May 2017 Location: Wolverhampton Posts: 259 ![]() ![]() ![]() |
Scottyav. Couple of questions if I may:
Fitted mine. Basically because I have so many things plugged in I didn't do anything fancy. The unit is next to the aux IN and plugged into the USB. All nice and neat.
@DMRR: Can you answer this one please?
Henda Member Since: 02 Aug 2018 Location: Gateshead Posts: 282 ![]() ![]() ![]() |
Update
No - it's comparable (remember to turn up the music on the source though - i.e. the phone) Land Rover Addict XXXXXXXXXXXXXXXXXXXXXXX Previous XXXXXXXXXXXXXXXX 2009 5.0V8SC Autobiography 2006 4.2V8SC Autobiography 2004 4.4V8 Vogue |
As above it is only a fraction lower but doesn’t alter the quality for me,sorry been away on a family passing 😢 _____________________________________________________
Thanks both for your replies.
