Home > In Car Electronics (L322) > Cd player
Henda
United Kingdom 2006 Range Rover Vogue TDV8 Zambezi Silver
Cd player
Well found my air guitar 3 cd album put it straight in lovely came back out later on looking for a clear road to blast out the sounds and yes you guessed it discs not recognised try the bang method and the air blast method nothing has worked so it looks like a new clarion 6 cd unit for me Evil or Very Mad
Well it wouldn't be a Landrover would it Rolling with laughter
Any body got a spare one Thumbs Up
Post #491286 7th Oct 2018 9:54am
mpirie
It might be better/cheaper to fit an Intravee unit and move over to MP3/iPod music instead?
Check the classifieds, i'm sure i saw one for sale recently.
Mike
Post #491324 7th Oct 2018 3:29pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
Unfortunately the Intravee only works on the BMW non touchscreen models. The later (2006) will need a diff rent method for iPod Neutral 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
2009 3.6 V8 (MY2010) - my first ever diesel! - now also gone Sad
2004 4.4 V8 Petrol Vogue - now gone
Post #491343 7th Oct 2018 5:16pm
chris_read
You need the Audio Connectivity Module - VPLME0004
There’s some on eBay at the moment for less than £200 Thumbs Up 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
Post #491344 7th Oct 2018 5:31pm
clemenz
Austria 2006 Range Rover Vogue Td6 Zermatt Silver
Also possible to replace the laser unit inside the cd changer Wink
Post #491549 9th Oct 2018 8:28am
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
Or get the Bluetooth receiver that goes through the aux port for £10, ive used one a few years no issues, wires hidden in box and right angle extension into the cubby box where it joins the remote wire that sits in front of the gear stick.
https://www.ebay.co.uk/itm/Bluetooth-Wirel...Swo4pYGYF8 _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #491568 9th Oct 2018 11:04am
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Neat! I've ordered one from Amazon - should be here tomorrow. My current solution is hard wired but doesn't allow me to stream from my phone - so MANY THANKS for the inspiration for this!!! Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #491571 9th Oct 2018 11:30am
Scottyav
Forgot to add i use this for the extension so i can close the rear lid on the aux port, i drilled a small hole and pushed it through and that's the best place as it misses the wiring and box under the ports,i left most of the cable under the cubby box and pushed the receiver wire into it and hid it under the box Thumbs Up
https://www.ebay.co.uk/itm/3-5mm-Jack-Ster...1438.l2649 _____________________________________________________
Post #491583 9th Oct 2018 12:44pm
Gyre8
England 2006 Range Rover Vogue SE 4.4 V8 Tonga Green
Scottyav. Couple of questions if I may:
Is the AUX in volume much lower than the Radio volume with this device?
Does this device affect or override the built in bluetooth handsfree/voice functionality (as it's a bluetooth device)?
Many thanks.
Post #491648 9th Oct 2018 9:14pm
DMRR
Fitted mine. Basically because I have so many things plugged in I didn't do anything fancy. The unit is next to the aux IN and plugged into the USB. All nice and neat.
Used Macrodroid to then tell my phone to open Spotify on connection to the BT device, pause for 1 second and then press play Smile
When I turn off the car - Macrodroid detects the disconnect to the BT device and pauses Spotify.
Job done - most excellent and a lot neater than the stupid iPod solution I had previously!!!!
*EDIT*
On my Pixel 2 I have told it that this device is STREAMING ONLY and the hands free BT on the car picks up call handling and contact sharing. It's awesome!!! Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #491710 10th Oct 2018 1:01pm
Gyre8
@DMRR: Can you answer this one please?
Post #491755 10th Oct 2018 5:48pm
Henda
Update
Having lost the CD player and looking at very expensive second hand units I decided to remove the player and get it refurbed
So yesterday morning out I went toolbox in hand pressed the CD player on the dash and bingo it starts to work again the only thing I did different this week was give the ff a good blast down the motorway , kept it in manual to keep the revs above 3000 to clear out the crap so it seems a good engine blast has sorted out the CD player Thumbs Up
Post #492369 15th Oct 2018 8:34am
DMRR
No - it's comparable (remember to turn up the music on the source though - i.e. the phone) Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #492400 15th Oct 2018 11:23am
Scottyav
As above it is only a fraction lower but doesn’t alter the quality for me,sorry been away on a family passing 😢 _____________________________________________________
Post #492470 15th Oct 2018 9:15pm
Gyre8
Thanks both for your replies.
As I'm sick of my ears being blasted when I switch from Aux in back to Radio, I've decided to try one of these:
https://bit.ly/2Ez8ETV
As you can see, it combines AUX in, Bluetooth and an amplifier (pre-amp?). Hopefully it will provide some volume punch and clarity to the BT music from my phone.
Post #492472 15th Oct 2018 10:06pm
