Home > Technical (L322) > 2011 4.4 TDV8 Charging system fault, performance restricted |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
Done many of these sir
6th Oct 2018 10:47pm |
longmanh Member Since: 11 Feb 2018 Location: Thames Ditton Posts: 104 |
You sir, are an absolute gent. Thank you.
7th Oct 2018 6:49am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2486 |
http://www.fullfatrr.com/gallery/albums/us...sioner.pdf
7th Oct 2018 9:15am |
Cheers Graeme.
7th Oct 2018 9:32am |
Having just looked at mine, I doubt it. If the fan shroud could be removed then it looks possible. |
7th Oct 2018 9:34am |
The fan shroud is removed with the fan which requires a/c pipes to be disconnected so not a roadside task. The only hope is that you can get a socket in without removing anything. If the belt has stayed on its other pulleys, which is highly unlikely, then you may have a chance. |
7th Oct 2018 9:40am |
Cheers for your help Graeme, much appreciated.
7th Oct 2018 9:52am |
I intend seeing if it is possible to change the belt without removing the fan and shroud but don't know when that might happen. The first hurdle would be to remove and refit the stretchy fan belt! |
7th Oct 2018 10:12am |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
longmhan, John w did his AC compressor recently and had to take serpentine belt off using 1/2" drive on the tension pulley. get in touch with him.
7th Oct 2018 10:15am |
Just had a quick look at one here, If you have a breaker bar (wheel nut bar) with a stubby extension, then you can put the belt on the tensioner without removing the shrouds... Makes life easier if you remove the main air intake pipe...
7th Oct 2018 10:38am |
I did a thread on this ages ago, all TDV8 4.4 owners should keep an eye on the this tensioner as it wears out...
7th Oct 2018 10:41am |
Thanks Craig. |
7th Oct 2018 11:19am |
7th Oct 2018 3:21pm |
Thanks again Craig.
8th Oct 2018 8:48am |
