Home > Technical (L322) > Air compressor
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Air compressor
Any help or pointers, I fitted a new Dunlop compressor to my 2011 4.4 as I was getting the compressor overheating info from my IID tool and the usual yellow triangle with bong then red triangle, do not exceed 30mph.
After fitting the new compressor cleared faults, steering reset after battery reconnection, works great up and down faster than before no warnings lovely jubbly.
Well, so I thought, after a couple of on off starts I get the bong and yellow triangle? normal ride height only? Plug in the IID tool and get the message algorithm communication fault?
Any ideas, what am I missing? Big Cry
Post #490478 30th Sep 2018 9:52pm
Baz1975
Northern Ireland 2015 Range Rover Autobiography SDV8 Firenze Red
Did you have any joy with your problem? Current: 2015 4.4 SDV8 Autobiography
Old: 2011 4.4 TDV8.... OMG
Old: 2003 TD6 HSE Java Black
Work: 2016 VW T6 140
Post #512425 17th Apr 2019 7:39pm
Tinman
After a few messages like before things settled down and are working well before I changed the compressor I renewed the front ride height sensor as I had a message come up with the IID tool that was the problem? I don`t think it was because I still had to replace the compressor.
Have you got a problem?
Post #512428 17th Apr 2019 8:15pm
Baz1975
Yes, just made a post there.
Saturday night, 'bong' suspension fault, max speed 30mph, stopped car, restated and drove a couple of miles and same thing. Restarted and raised car to full height and then access height, returned to normal height, drove another couple of miles and same again, then 'compressor over temp' (I think was the exact words) got car home and left it.
Sunday, drove 40 miles with no issues.
Monday, drove 3 miles up the road and same fault, 'bong' suspension fault, max speed 30mph. Returned home, car goes up & down with now issues. Removed compressor cover and found the compressor very hot. Started car, steering wheel lock to lock and compressor cutting in & out as required with no issues. When driving, you can hear the compressor (left cover off etc) kicks off after 1 minute or so, ok for a few miles then all of a sudden 'bong' suspension fault, max speed 30mph, as soon as this happens, you can hear the compressor pulsing out air.
Phoned my INDY (who is away on holiday for Easter) he said, 1st thing to replace compressor. Left the car on full height mode for 2 days, no dropping at all.
Replaced the compressor & relay tonight, out for test drive and 'bong' suspension fault, max speed 30mph, again, as soon as this happens, you can hear the compressor pulsing out air.
Not happy, been searching through posts but unable to find something similar.
Any pointers would be greatly appreciated
Thanks in advance
B Current: 2015 4.4 SDV8 Autobiography
Post #512434 17th Apr 2019 8:50pm
Tinman
Do you have an IID tool? I know of I, RST Landrovers Ltd, 1-3 Kingsland Road, West Mersea, Essex, CO5 8RB or a couple in Kent
Sorry that Indy out of your area.
Post #512438 17th Apr 2019 9:06pm
Baz1975
No, I don't. I'm hoping my sons mate will call in over Easter & connect his up.
Thanks Current: 2015 4.4 SDV8 Autobiography
Post #512440 17th Apr 2019 9:19pm
muddycharles
United States 2008 Range Rover HSE 4.4 V8 Bonatti Grey
Compressor Type
If you changed the compressor type from old (Made by Hitachi) to new (made by AMK) you need to reflash the suspension with the IID tool. This could be a reason for your problem (assuming the physical parts and bits are ok) 2008 HSE B. Grey
Overfinched
NavTV retrofit
Post #512582 19th Apr 2019 1:46pm
AJGalaxy2012
This type of behaviour is exactly what mines doing now but thats because of it needing a new air bag on the front offside. If I put the suspension on high I can hear loads of air escaping. On access height or normal it's fine, no air leak etc until I hit a bump or accelerate, it then sounds like a lorries air brakes, not sure if thats what you meant by pulsing.
AJG BMW i3 Electric Car
2006 VW Touareg 3.0 TDi V6
Post #512589 19th Apr 2019 2:24pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Tinman, did you resolve your issue?, as I'm having exactly the same problem.
Was going down the new compressor route aswell, But I don't believe that's the issue & after reading your post It's convincing me even more Rolling Eyes
Post #513495 28th Apr 2019 6:47pm
Gsxr1250dave
Im changeing my front off side bag this week iv a leak get in there with some soapy water
Post #513496 28th Apr 2019 7:52pm
Highroller
Dave, had a good look & squirt, no bubbles. Did it at Normal height, any advantage of doing it at off road height (although I suppose it wouldn't hurt). Good luck with yours. Thumbs Up
Post #513591 29th Apr 2019 6:53pm
yelnats69
United Kingdom 2011 Range Rover Vogue 4.4 V8 Zambezi Silver
Did this cure your problem
Post #540857 17th Jan 2020 9:14am
